Old 01-21-2022, 09:17 AM   #1
8man
ABS Kick panels
I need to cover the kick panels, as the driver's side still has the inside louvers for the old side vent. I had planned on covering the kick panels and looked at these early on. It is time to put some speakers in the kicks and so I'm behind again.
I am looking at the White Wolf ABS kick panels. Has anyone used them, or any other interior kick panel?
I see a number that say "cardboard", but I think I want the ABS material, unless someone can tell why not.
Any help is appreciated.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-21-2022, 09:52 AM   #2
youngrodder
youngrodder's Avatar
Re: ABS Kick panels
I would just make your own. You can get various sized ABS sheets on Amazon. I purchase 4' x 8' sheets. It is easy to work with if you order 1/16" thick. Before I made my kicker boxes I made some simple kick panels out of ABS and I just tucked them in the windlace in the door to hold them into place. They could be easily covered with material if your choose. I didn't waste the time as I knew mine were temporary since I would be replacing them with speaker pods at some point.
I used the ABS for my door card backers as well as my other interior panels.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-21-2022, 10:03 AM   #3
8man
Re: ABS Kick panels
Thanks for the suggestion. How did you cut it? At 1/16 I'm guessing it was fairly flexible, right?
8man-aka Robert
Old 01-21-2022, 10:18 AM   #4
youngrodder
Re: ABS Kick panels
Yeah very flexible but not flimsy. It can also be heated if you need more form. You can cut it with a Stanley knife, a cut off wheel. For my headliner I used metal tin snips. Anything thicker than 1/18" it will be harder to slide it under the windlace.
Marc
Old 01-21-2022, 10:19 AM   #5
8man
Re: ABS Kick panels
Thanks, I just looked it up on Amazon. I think I'll try it.
8man-aka Robert
Old 01-21-2022, 10:30 AM   #6
8man
Re: ABS Kick panels
One more question for now. Is the 1/16" thick enough to hold its shape? I mean for the roof for instance or the door panel?
Thanks for the help.
8man-aka Robert
Old 01-21-2022, 10:37 AM   #7
youngrodder
Re: ABS Kick panels
Your welcome. Yes, I posted a pic on my build thread of my headliner I'm working on. Again you can always use heat to help form. For my headliner, each section is made up of compound curves. Once it is all in, I may go back and heat it to relax the tension some.
For my door cards I used 3/16 foam over the ABS then wrapped with material. I think 1/16" by itself would look too thin and flimsy for door cards.
Marc
Old 01-21-2022, 08:27 PM   #8
gsinon
Re: ABS Kick panels
I bought a set of these with included speaker pods for my 51.
Glenn
1951 3100, Area51
1955 BelAir, 4EVER17
1987 R10, Ethel
Copper Hill Rod & Custom
http://67-72chevytrucks.com/vboard/s...d.php?t=829856
gsinon is offline   Reply With Quote
Old 01-21-2022, 09:57 PM   #9
_Ogre
_Ogre's Avatar
Re: ABS Kick panels
Cheap enough and easy to make out of fiberglass
Check out my build thread
shop air compressor timer
Old 01-22-2022, 07:14 PM   #10
SFFD103
SFFD103's Avatar
Re: ABS Kick panels
https://ls-fab.com/custom-autosound-...anel-speakers/
SFFD103 is offline   Reply With Quote
Old 01-23-2022, 02:23 PM   #11
youngrodder
Re: ABS Kick panels
If you give me your dimensions, I probably have enough scrap material for kicker panels. You cover the shipping and its yours.
Marc
Old 01-23-2022, 05:37 PM   #12
8man
Re: ABS Kick panels
Marc,
Thank you for the offer, it is very generous. I think I'm going to try it myself. As I've said, I keep learning as I go. However, if I butcher it too bad, I'll be in touch.
8man-aka Robert
Old 01-23-2022, 05:39 PM   #13
8man
Re: ABS Kick panels
Gsinon,
Thanks, but I have a set that look a lot like those. Laura took one look and said it was not what she wanted. So, I'm going to flat with smaller speakers inset.
8man-aka Robert
Old 01-24-2022, 11:19 AM   #14
youngrodder
Re: ABS Kick panels
Marc,
That is the best way to lean ANYTHING, to try things yourself...
It's pretty easy stuff to work with, I'm sure you will be fine.
Marc
