Old 05-01-2019, 12:50 AM   #26
Captainfab
60-66 Nut
Re: Another turbo ls
I gather that the new differential is a Moser Dana 60?
Old 05-01-2019, 01:43 AM   #27
p0508
https://photos.app.goo.gl/suN7jsh4uRJqrdzN8
This turd is getting a turbo in the next month or so if I can find the time. Neighbor down the street has a 66 c10, I never looked twice at them till I was around his, Now i might like them more than 67-72s. Looking good man, keep up the good work, let me know how that moser works out.
p0508 is offline   Reply With Quote
Old 02-17-2020, 03:43 PM   #28
jrusher
Originally Posted by C10matt View Post
Attachment 1886728
I finally got some more stuff. VS racing 7875 billet and a cx racing intercooler 25x12x3 which looks like it'll fit nicely with only cutting for the elbows. Now to get to work haha.
Nice work/build! I oredered a 31"x12x3" intercooler for my 65 but it will be too much hacking on the rad support. Yours looks like it will fit well with minimal cutting of support. Thx for info
jrusher is offline   Reply With Quote
Old 02-18-2020, 10:25 AM   #29
cookseyb
Good Job! But I wish you would clean up that nasty ass engine!
cookseyb is offline   Reply With Quote
Old 02-18-2020, 11:48 AM   #30
SkinnyG
SkinnyG's Avatar
This is my 31x12x3 intercooler - sliced the vertical parts of the rad supports to fit the ends, but it will fit behind an un-cut '61 grill.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 02-21-2020, 12:47 PM   #31
Android04
Android04's Avatar
Looking good.
Android04 is offline   Reply With Quote
Old 11-05-2021, 04:13 PM   #32
C10matt
C10matt's Avatar
Between moving and life this was put on hold but I've finally got to give it some attention mostly part gathering but I did cut some plates for the TRZ anti roll bar
C10matt is offline   Reply With Quote
Old 12-17-2021, 03:34 PM   #33
C10matt
C10matt's Avatar
I had a little time today to start mocking up the new FSP log manifold and 4" down pipe. Kinda glad things are going slow, this is a much nicer setup.
Old 12-17-2021, 08:04 PM   #34
The Rocknrod
Moderator
The Rocknrod's Avatar
Looks like it's going to be a runner. Nice so far.
Old 12-20-2021, 06:29 PM   #35
C10matt
C10matt's Avatar
I was able to get my Aldan coil overs mocked up today
Old 12-21-2021, 02:36 PM   #36
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice progress!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-21-2021, 08:05 PM   #37
88Stanger
88Stanger's Avatar
I do not have turbo on my LS but i do have the Holly Wire system. All in except for a few hard wires. From what i have heard it is a great system.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-23-2021, 07:43 AM   #38
The Rocknrod
Moderator
What rear end cover is that?
Old 12-23-2021, 08:24 AM   #39
SkinnyG
SkinnyG's Avatar
Dana 60
Old 12-23-2021, 02:58 PM   #40
C10matt
C10matt's Avatar
Yeah that's the Moser version of a Dana 60
Old 01-13-2022, 08:37 PM   #41
C10matt
C10matt's Avatar
I gotta around to doing the coilovers on the front end this week
Old 01-18-2022, 09:39 AM   #42
aggie91
aggie91's Avatar
Nice! Who's front coiler over kit did you use?
Karl
The LST Challenge:
Old 01-18-2022, 11:27 AM   #43
SkinnyG
SkinnyG's Avatar
I'd like to see a 3/16" or 1/4" thick ring at the bottom of the old spring pocket to spread the load of the coilover mount over such thin sheet metal.
Old 01-18-2022, 02:51 PM   #44
C10matt
C10matt's Avatar
Thanks. Thats the Viking shock CPP kit but the 550lb springs it came with were way too stiff so those are 350lb QA1s
Old 01-18-2022, 02:54 PM   #45
C10matt
C10matt's Avatar
Ive done this with A bodys that leave with the wheels up never had a problem
Old 01-18-2022, 09:17 PM   #46
SkinnyG
SkinnyG's Avatar
Absolutely.
But also..... for how long?
You don't have to do any of it, but from an engineering standpoint, that's a lot of point load on a relatively small surface area.
Old 01-26-2022, 02:18 PM   #47
C10matt
C10matt's Avatar
Absolutely.
My El Camino is still running that same set up to this day just with a different owner ... that's over 12 years no issues.
That pic doesn't show good enough but mount on the coil over is actually wider then the flat surface of the control arm therefore distributing the weight across the old spring pocket
Old 02-03-2022, 07:09 PM   #48
C10matt
C10matt's Avatar
Got some more of the exhaust mocked up, now I'm debating where to put the electric cut out...
Old 02-05-2022, 07:14 PM   #49
C10matt
C10matt's Avatar
Tucks up pretty good for 4" pipe
Old 04-05-2022, 05:31 PM   #50
C10matt
C10matt's Avatar
I was able to get a bit done last weekend, got the old trailing arm cross member out and the POL one in and the Moser trailing arms installed
