Old 02-01-2022, 05:24 PM   #1
pwdcougar
pwdcougar's Avatar
instrument cluster seal
Took apart my cluster to restore it and cant remember where the rubber seal went. The replacement seal is "cut to fit". The old seal was 1-1/2" long or so pieces spaced out around the cluster. The old one was crusty so I cleaned it off and no trace of where it was placed remains. The new seal is about a quarter inch in diameter. It went between two parts but no idea which two.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-01-2022, 06:58 PM   #2
pjmoreland
pjmoreland's Avatar
Re: instrument cluster seal
Nice looking gauge cluster. If you're referring to the pieces that look like black tootsie rolls, then six of them go between the back of the bezel and front of the lens. They sit on the ribbed sections of the bezel.
pjmoreland is offline   Reply With Quote
Old 02-01-2022, 08:00 PM   #3
pwdcougar
pwdcougar's Avatar
Perfect! Thanks!
Old 02-01-2022, 08:48 PM   #4
thegarty
New Member
thegarty's Avatar
Sorry to barge in, I replaced my cluster last fall, re-installed in my truck. Afterwards, I noticed the six tootsie rolls were still stuck in my old cluster. Should I take my cluster back out and install them or will this hurt any of the gauges running without? Thanks.
thegarty is offline   Reply With Quote
Old 02-01-2022, 08:56 PM   #5
pjmoreland
pjmoreland's Avatar
My assumption is that they're there to prevent the lens from rattling. I don't know for sure, but I doubt anything catastrophic will happen if you leave them out.
Old 02-01-2022, 09:06 PM   #6
thegarty
New Member
thegarty's Avatar
I felt pretty good after I finished putting the new cluster in, next day I went in the basement to clean up and store the old cluster away, and that's when I seen them. Felt pretty silly after I found them and missed re-installing them. Stupid me....ha! Thanks for your input.
Old 02-01-2022, 09:13 PM   #7
pjmoreland
pjmoreland's Avatar
I've had my gauge cluster out of my truck more times than I care to admit! Mostly it had to do with chasing down illumination issues associated with a poorly made reproduction lens and tins. Thankfully, I was able to source OE parts.
Old 02-01-2022, 09:43 PM   #8
Toro
Toro's Avatar
That's an interesting looking tach, what model is that? The markings and numbers look different than most of the ones I've seen. Thanks
Toro is offline   Reply With Quote
Old 02-01-2022, 11:16 PM   #9
pwdcougar
pwdcougar's Avatar
The tach is from a 75-80 something Camaro. A board member named Grincoloco did a write up on installing one to use with a later model distributor.
http://67-72chevytrucks.com/vboard/s...d.php?t=250683
