07-24-2004, 07:11 PM | #1 |
new header question
I just installed coated headers. When I am checking the collectors for leaks and I am under the truck and it is revved up both collectors make a pingging sound what I would think was a leak. But I can feel no real air leak with my hands? Do headers make this sound more so than manifolds? I can only hear it when under truck? Thanks.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
07-24-2004, 07:21 PM | #2 |
ya, they are a little more noisy b/c they are made of thinner material. When you have a leak, you will definately hear it in the truck. Did you use the aluminumn collector gaskets? When you have to change them, use those they are work the extra $$$.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
07-24-2004, 08:01 PM | #3 |
yes I did use summit brand aluminumm gaskets. other than the sound will a gasket leak damage anything?
07-25-2004, 12:18 AM | #4 |
It shouldnt, just dont drive it much. I went through many a paper gasket before the aluminumn ones came out (or I found them). For some of that time the '78 was my daily. I would not go much more than a day with a leak though b/c the noise will just drive you crazy.
Sorry I can't help with your other problems. I would call dynomax and see what they say about it.
07-25-2004, 12:44 AM | #5 |
mine must not be leaking then It does not bother me daliy driving only in garage or under truck other wise I do not hear it.
