Old 02-04-2022, 10:54 AM   #11
SRU1436
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Originally Posted by LockDoc View Post
I had a little time to kill so I decided to get started on setting up the ECM using my HP Tuners software this morning. I got it all connected and the laptop fired up. I built a wire loom so I could do all of the ECM programming stuff on the dining room table. It makes it a lot more enjoyable to be able to sit down in comfort......
I got the original tune scanned and backed up to my hard drive, now I can go in and remove the VATS, EGR, rear 02 sensors, A/C, and 4x4 stuff. There are a few other things but I will have to look at my cheat sheet and double check. It has been quite a while since I did my '67 Panel Truck.
In the picture, the large grey box in the back is the regulated 12v power supply. I has the rocker switch that turns on the power to the ECM sitting on top of it. The large silver box is the ECM (Truck Computer), and on top of it is the Diagnostic connector from under the dash of the donor truck. It has the cable from the HP Tuners interface box plugged into it. The small grey/black box is the HP Tuner interface that connects the ECM to the PC.
The PC will read the "tune" in the ECM, then you can make changes to it and write the modified "Tune" back to the ECM computer. The only thing you really have to remove to make the engine run is the VATS (key resistor chip) information that would keep the engine from starting.
I'm sure some of this stuff will be pretty boring to some but I want to document it for future reference.
LockDoc
Wow that’s pretty trick. I never knew what you’re doing was possible. But then again I never looked into something like that.
Last edited by LockDoc; 02-04-2022 at 02:02 PM. Reason: Corrected the spelling in my quote
SRU1436 is offline   Reply With Quote
