Old 02-03-2022, 08:38 AM   #1
67chevemall
67chevemall's Avatar
Block stamp?
9v147450
Anybody know how to read this one?
283 or 307 or?
1968 c10
Truck had its heads taken many years ago.
The good it sat in a barn. All there.
The bad i need a set of heads.
And the front window is toast.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-03-2022, 11:31 AM   #2
MJN
MJN's Avatar
Re: Block stamp?
Any other numbers you can add? Are you sure those are the numbers/letters that are stamped on the front RH side pad of the block? Suffix codes that tell you the engine specifics are made up of letters- typically in the following format after 1956.
T02I4IT
First letter is the engine plant
Next four digits are the build date
The last two or three letters are the suffix code
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 02-03-2022, 01:58 PM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Block stamp?
Well if it has no heads just measure the bore & stroke. No guess work involved.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 02-03-2022, 05:32 PM   #4
BigBird05
Re: Block stamp?
Take a picture of it.
BigBird05 is offline   Reply With Quote
Old 02-03-2022, 05:52 PM   #5
67chevemall
Re: Block stamp?
Be a few months before any wrenching and measuring.
Old 02-04-2022, 09:19 AM   #6
1970 CST
1970 CST's Avatar
Re: Block stamp?
Here is a link to use for identifying small block chevy's.
https://nastyz28.com/chevy-engine-code-stampings.php
1970 CST is offline   Reply With Quote
Old 02-04-2022, 09:52 AM   #7
67chevemall
Re: Block stamp?
I spent a good hour on there. No luck
Sept flint ....
Old 02-04-2022, 09:55 AM   #8
67chevemall
Re: Block stamp?
Going to get new cast heads from summit.
It must be a 283 from 67 or 307 from 68.
These new heads seem to fit both.
Doesnt the 283 and 307 use the same block?
Old 02-04-2022, 10:02 AM   #9
Getter-Done
Getter-Done's Avatar
Re: Block stamp?
I cannot find the Link that states that Remanufactured Engines are assigned a new number sometimes.
This may be the case with this one.
With Numbers like that it is a Possibility that it was rebuild by a business-like Grooms (http://crateenginesupply.com/grooms-crate-engines/) or Jasper (https://www.jasperengines.com/)
The early bird gets the worm,
84 Chevy K-20
Old 02-04-2022, 03:00 PM   #10
MJN
MJN's Avatar
Re: Block stamp?
Can you see the block casting number on the LH rear by the bellhousing? The Lime Book also has lots of good info in it but nothing that matches those numbers.
http://camaros.org/pdf/LimeBook.pdf
'17 GMC Yukon XL
VCCA member #58596
Old 02-04-2022, 06:08 PM   #11
67chevemall
Re: Block stamp?
Ya i am stumped.
3 more feet of snow today.
Few days ill see what other numbers
i can find
Old 02-04-2022, 07:20 PM   #12
Drew1968
Drew1968's Avatar
Re: Block stamp?
MJN is correct, this is the block casting number you need to locate...this will determine what you've got. Once you've located the number, just Google small block casting numbers and you should be able to determine bore, stroke, year mfg, where mfg. ect. Good Luck!
Drew1968 is offline   Reply With Quote
Old 02-04-2022, 11:29 PM   #13
68bowtie
68bowtie's Avatar
Re: Block stamp?
Can’t help with the block question, but I want more pictures of this truck!
