Old 02-05-2022, 12:31 AM   #1
bullington
All around good guy
bullington's Avatar
Lift 1971 Suburban
Bought a RoughCountry 4" lift with front and rear springs, shocks, raised steering arm, etc etc.
Will be putting 900-16 tires on it when completed.
bullington is offline   Reply With Quote
Old 02-05-2022, 01:28 AM   #2
pwdcougar
pwdcougar's Avatar
Re: Lift 1971 Suburban
That will make a significant difference in stance!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-05-2022, 11:06 AM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That is going to look killer!
Ryan
1969 Chevy milk truck
Old 02-05-2022, 02:24 PM   #4
bullington
All around good guy
bullington's Avatar
Lift was installed. The front lifted 4" and the rear lifted 2". Measured from center axle to fender.
Called RoughCountry and showed them what was going on and I was told that the rear is taller and the rear spring is purposely 2" shorter to "level" it out. It is noticeably shorter in the rear by 2" (measured)
The wheel looks off as I couldn't get back far enough to stand center.
Old 02-05-2022, 06:00 PM   #5
Bigdav160
Bigdav160's Avatar
I think those kits are the same for trucks (with a lighter bed)
I had to add blocks to the rear to level my Suburban out.
And an offset plate too get the axle centered in the wheel well
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-06-2022, 09:38 AM   #6
52napco
My K20 has a 4" with 285-16 tires ...blocks on rear so my tire is centered in rear... I'm
Going to drop it down a little this year with ALCAN springs.
52napco is offline   Reply With Quote
Old 02-06-2022, 03:41 PM   #7
bullington
All around good guy
bullington's Avatar
Thanks for the tip
Old 02-06-2022, 03:42 PM   #8
bullington
All around good guy
bullington's Avatar
Did you have problems with it being lower in the rear?
Old 02-06-2022, 04:04 PM   #9
52napco
Yes...5" block in rear w 4" front springs...gonna do a 2.5" instead....burbs are super heavy on the rear so I'll
Get a buddy to measure all 4 corners so I can get it spot on
Old 02-06-2022, 06:05 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Nice burbs... Nothing wrong with a lifted burb.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-07-2022, 05:26 PM   #11
bullington
All around good guy
bullington's Avatar
I got it figured out. Added a Superlift Add-a-Leaf to the new rough country springs along with the OEM overload spring and it is now sitting level at all four corners.
Will post up all the data, parts, and photos soon. Night pic after getting it done.
Old 02-07-2022, 06:08 PM   #12
72gmguy
72gmguy's Avatar
Looks right! Love lifted burbs!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 02-07-2022, 07:34 PM   #13
bullington
All around good guy
bullington's Avatar
Thanks. I'm glad it worked out the second time.
Old 02-08-2022, 04:24 PM   #14
vectorit
What?
vectorit's Avatar
Looks great!
What wheels are those?
OE or new Wheel Vintiques?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-08-2022, 04:42 PM   #15
bullington
All around good guy
bullington's Avatar
Originally Posted by vectorit View Post
Looks great!
Thanks!
Wheels: https://www.summitracing.com/parts/w...70604/overview
Tires: https://www.cokertire.com/tires/sta-...ly-900-16.html
Old 02-08-2022, 07:37 PM   #16
vectorit
What?
vectorit's Avatar
Did you have to run any wheel spacers for the offset?
I ran into this with the same wheel, just not the smoothie version on my '72 k10 PU. The wheel was too close to the disc brake caliper.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-09-2022, 09:49 PM   #17
bullington
All around good guy
bullington's Avatar
I didn't though I thought it was going to be an issue. Stock calipers and rotors.
Will take a pic with measurement for posterity.
Old 02-10-2022, 04:44 PM   #18
bullington
All around good guy
bullington's Avatar
A couple of daytime pics of the lift and tire combo
Old 02-10-2022, 07:13 PM   #19
vectorit
What?
vectorit's Avatar
Looks great!
In case you haven't yet, be sure to make sure your front drive shaft is in good shape after the lift. In my case since mine was running at a very low angle for 30+ years when I raised the suspension, I found that the slip yoke was worn out and needed to be replaced being at the new angle.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-10-2022, 08:29 PM   #20
bullington
All around good guy
bullington's Avatar
Looks great!
Great advice!
Luckily everything checked out. The original owner didn't use it much so not much wear and tear on it.
Old 02-12-2022, 10:36 AM   #21
Dieselwrencher
It looks really nice but man, I could not live with the rear axle so far forward in the wheel well. Move that thing back.
It looks like if you load anything in the back, or hook up a trailer, you're going to hit the quarters in front of the tires.
Ryan
Old 02-15-2022, 04:33 PM   #22
bullington
All around good guy
bullington's Avatar
Thanks for the feedback. Once I get it flexed and settled will measure and see where it needs t be!
Old 06-02-2022, 06:14 PM   #23
72FamilyBlazer
Hey hey old thread, did you ever adjust your rear end position?
72FamilyBlazer is offline   Reply With Quote
Old 06-03-2022, 12:57 AM   #24
Richard
Axle moves back as suspension cycles up. Especially with higher arch springs. Bet most would be surprised how much if you cycle the suspension to full bump.
Richard
Old 01-05-2023, 04:22 PM   #25
bullington
All around good guy
bullington's Avatar
No need. Everything works as designed and flexes nicely.
