59 factory cab mount diagram
Anyone have a diagram for replacing factory cab mounts? Original bolts and bushings were removed long ago and I'm replacing them with a new kit from LMC. I want to make sure all my shims and bushings are correct. Thanks
![]() Join Date: Apr 2017
Re: 59 factory cab mount diagram
instructions here
http://chevy.oldcarmanualproject.com...55ctsm0102.htm pictures here http://67-72chevytrucks.com/vboard//....php?p=5236748 |
google
55-59 chevy truck factory assembly manual pick the tri5.com site download the manual and either save it or peruse it. I suggest download and keep a copy becuase there is a lot of valuable knowledge there with drawings, dimensions and the correct way to assembly pretty much everything on the truck. it shows where every spot weld is and how the factory put things together, how te wiring is strung along and each connection etc etc |
And you should look for the 1957 dealer accessory manual because it shows bits and pieces not found in the assembly manual.
There's also the 1955 2nd series shop manual online if you need it |
