67 fender badge
I'm wanting to put fender badges on my 67 but don't have holes for them. Did body work and covered them. Question is has anyone ever cut the prongs off the badge and used 3m double stick tape to apply them? Been searching the internet for stick on badges with no luck.
#2 | |
Re: 67 finder badge
With that said, if another member has fenders loose, it would be easy enough to make (left/right) 'templates' (or reference the assembly manual) for hole location.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
Who Changed This?
![]() Join Date: Jan 2013
Re: 67 finder badge
What is a "finder badge"?
When I had my '68 Skylark, I stuck the "GS" badges on the "C" pillar with double-sided tape. I never was able to find those "serrated nuts", for lack of a better name for them. I managed to wrestle them off when I went to a painted top from a vinyl top. They didn't leak water into the car, with the double-sided tape.
#4 | |
BlahBlahBlah
Re: 67 finder badge
Active Member
![]() Join Date: Apr 2017
Re: 67 finder badge
I applied the trunk emblem on my 77 camaro with black 3m double sided tape. 10 years and maybe 20 hand washes later and it's still hanging on!
Re: 67 fender badge
Thanks for the suggestions. And yes it's "fender badge" sorry for the mistake
![]() Join Date: Aug 2019
Re: 67 finder badge
I have the fenders off of my 72 C-10, can I help with any hole location. PS I would use 2 sided tape and not put holes in your fenders.
Re: 67 fender badge
ordered a set from classic industries today. My plan is to cut the prongs off and use some type of tape to stick on the fenders. I will post my progress. Thinking i need to add side view mirrors too.
Re: 67 fender badge
I was thinking about your idea about cutting the tabs off. You might try this idea on a scrap emblem. After cutting the tabs off fill in the void area with epoxy and sand flat. That would give more surface area for the tape.
Re: 67 fender badge
Your emblems will sit away from the fender and in my opinion become a dirt collector. I put the upper trim on my 68 and yes drilled all the holes for the clips. Every time I look at the trim I'm happy that I took the time to do it right. Good luck and be happy.
#11 | |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Re: 67 fender badge
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#12 | |
![]() Join Date: Dec 2009
Re: 67 fender badge
