01-28-2022, 03:01 PM | #1 |
steel wheel offset
Did the factory steel wheels have different offsets between the front and rear?
01-28-2022, 04:03 PM | #2 |
All about them K’s
Re: steel wheel offset
Not that I’m aware of. Are you having issues of some sort?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-28-2022, 04:23 PM | #3 |
I am trying to piece together a set and I bought some mid 70s gm
Van wheels without noticing the difference in offset Someone local to me said they had different offsets in the front and back But I thought that was wrong since the front ends have a wider track The top picture is the van wheel - this has about .5 less offset The bottom picture is an original wheel Last edited by GMC71k20; 01-28-2022 at 04:45 PM. |
01-31-2022, 12:14 PM | #4 |
The only time I have seen a difference in back spacing is in different size diameter rims, 16" verses 16.5" and 17", 17.5"
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-02-2022, 12:41 AM | #5 |
Not sure if you are working with a drum or disc 3/4 ton, but if its drum, be very careful of clearance caused by offset, or rivets vs welded. Some cause very slight distortion of the drum that causes endless headaches and eventually ruins very hard to get drums (ask me how I know).
Hope this helps Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
02-07-2022, 06:53 PM | #6 | |
They are the same within the same vehicle, as in front to rear. They would "have to be" to do the typical X shape tire rotation.
However vans are different from trucks, they are usually narrower too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-09-2022, 10:38 AM | #7 |
Vans came with flatter wheels, more backspace. Same with the 5-lug van rallye wheels being 7"
