Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 10-22-2020, 10:02 PM   #426
jessemthompson
Re: Camaro Caliper Brackets
I’d like to place an order for a set.
jessemthompson is offline   Reply With Quote
Old 10-22-2020, 10:20 PM   #427
Captainfab
60-66 Nut
PM sent.
Old 10-23-2020, 09:28 AM   #428
b454rat
How much difference between the Camaro and the Impala caliper? Want to get a set of these, assuming still making them? Also would these work for newer trucks? I have a 98 Tahoe 2wd.
Old 10-23-2020, 08:58 PM   #429
Captainfab
60-66 Nut
I fabricate all of my products everyday. This is one way I attempt to make a living. These will not work on the '88+ 10 bolt.
Old 10-23-2020, 09:27 PM   #430
b454rat
How much of a difference is there between those axles? I wouldn't think much, but don't have either of the other ones in front of me...
Old 10-23-2020, 10:44 PM   #431
Warrens69GMC
Warrens69GMC's Avatar
subbed.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-24-2020, 09:33 PM   #432
Captainfab
60-66 Nut
There is enough of a difference they won't work. The backing plate bolt pattern is completely different, the backing plate register is larger and the brake offset is wider. And then to complicate it even more, there are 10 bolts with the 10" brakes and 10 bolts with the 11" brakes. All of the above are different again. This is why in post #1 of all of my rear disc conversion brackets, the '88-'98 10 bolts are not listed.
Old 10-24-2020, 11:56 PM   #433
b454rat
Since I first posted I’ve been reading up on it, sounds like a pain to cover all of em
Old 11-17-2020, 12:26 PM   #434
ilnvyb360
ilnvyb360's Avatar
Sub’d. This is on my list of upgrades.
ilnvyb360 is offline   Reply With Quote
Old 05-10-2021, 08:23 PM   #435
Barba Negro
I'd like to put in an order for a powder coated set. Thanks, Kyle
Barba Negro is offline   Reply With Quote
Old 05-10-2021, 09:29 PM   #436
Captainfab
60-66 Nut
PM sent.
Old 06-27-2021, 08:25 PM   #437
Captainfab
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
Old 12-14-2021, 12:34 PM   #438
jdalexa84
Found a fantastic deal on a set of calipers that are complete with bracket and dampner on amazon. Under 100 dollars at time I am posting. I ordered my set and they look great.
Callahan CCK11355 [2] REAR... https://www.amazon.com/dp/B06Y44Z6TX...p_mob_ap_share
jdalexa84 is offline   Reply With Quote
Old 12-16-2021, 10:37 PM   #439
Captainfab
60-66 Nut
Thanks for posting that link to those calipers, that is a good deal!
Old 01-08-2022, 08:21 AM   #440
jessemthompson
I got around to installing my brackets last night. The parts fit great. Has anyone had an issue of the calipers not being able to hold the rear wheels with your foot on the brake? I noticed the truck lost significant braking power, so I jacked up the rear end and the calipers grab and release with the pedal fully depressed. I started doing some research and it seems these calipers have given some Z28 owners fits. I could not find a resolution online. I’m going to see if I can adjust the Allen for the parking brake to see if this helps. I didnt know if anyone else here has had this same issue.
Old 01-30-2022, 07:06 AM   #441
RoyL
RoyL's Avatar
Good price! Can you confirm they include the E-brake brackets and dampener? Photos looks like they do, but you never know about their photo accuracy.
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 02-06-2022, 07:56 AM   #442
RoyL
RoyL's Avatar
I decided to order these calipers from Callahan, they do include the bracket and 'dampener.' Will be awhile before I install, but they look good. The dampener is quite large... bigger than it looks in the photo...
1965 Suburban
Old 02-09-2022, 01:09 PM   #443
Benchracer
Benchracer's Avatar
[QUOTE=RoyL;9030706]I decided to order these calipers from Callahan, they do include the bracket and 'dampener.' Will be awhile before I install, but they look good. The dampener is quite large... bigger than it looks in the photo...
NOOB Question: What is that "Dampener" for?
This is my first Chevy and I'm still learning.....A LOT.
1971 Chevy C-10 (all original)
Benchracer is offline   Reply With Quote
Old 02-10-2022, 09:40 PM   #444
RoyL
RoyL's Avatar
[quote=Benchracer;9032407]
All I know is that it's called a "vibration dampener."
1965 Suburban
Old 03-01-2022, 02:50 PM   #445
Alex69c10
Hey, I’m interested in a set of these, though I’ve currently got a 69 12 bolt with 6lug drums. I’m going to swap out the axles with 5 Luger mosers, would these work with that set up? Then just to find calipers and discs if they do.
Alex
Alex69c10 is offline   Reply With Quote
Old 03-01-2022, 03:42 PM   #446
Barba Negro
Yep. Make sure you check all the bearings and seals. I just did the same thing on my 67 GMC. I bought Moser axles from summit. The caliper and rotor combo all depends on whether you are doing an e-brake or not. I bought a new brake booster/ master/ prop setup when I converted. Mine works awesome.
Old 03-01-2022, 09:03 PM   #447
Alex69c10
Awesome thank you! Appreciate the information.
Captain, I’ll take a set if you have one.
Old 03-01-2022, 10:51 PM   #448
Captainfab
60-66 Nut
These Camaro caliper brackets use a caliper that has a built in e-brake. There is no other option with these brackets.
Old 03-17-2022, 07:13 PM   #449
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 09-18-2022, 08:30 AM   #450
RoyL
RoyL's Avatar
[quote=RoyL;9033093]
For all you folks that have installed this kit, did you try it with and without the dampener? Wondering if it's critical to the braking performance?
Thx,
Roy
1965 Suburban
