Old 01-26-2022, 11:28 PM   #201
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I decided on a tire size for the rear. 245/50r18. I'll see if they clear on the front end and might just run that size on all 4 corners. I pushed it outside to try and get an uncluttered look at the stance, but it's dark so I used the high beams on the station wagon for the picture.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 01-26-2022, 11:33 PM   #202
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
And, for my next trick........ Harley roadglide headlights and bezels. I spent $65 in these factory lights to see if it would be possible to adapt them to the 58-59 fenders. I might have to cut up a pair of factory bezels to get the HD bezels to work, but I'm up for the challenge. If it works out like I hope it will, I'll get the led versions. They're like $150/ea so I think $65 is a good investment to make sure first
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-27-2022, 10:02 PM   #203
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I had to trim a bit of the headlight opening to get the headlight high enough in the pocket to make the bezel fit flush, and I'll have to make a small filler piece below the bezel to close the gap, but they'll work.
Also, I included the headlights I want to use. I think they look like cat eyes or alien eyes.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-28-2022, 07:56 PM   #204
daveshilling
daveshilling's Avatar
Re: 1958 Saab story
Wow, that's a great observation that the design is so similar between the two! I wonder how the Harley beams are setup to shine down the road as a motorcycle vs. an auto... should be pretty darn bright!
daveshilling is offline   Reply With Quote
Old 01-29-2022, 08:22 PM   #205
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I spent most of today fixing the oil leak coming from the engine oil pan. It's a 2-piece oil pan off a 2004 Corvette. I had to remove the crossmember and let the rack and pinion dangle to remove the pan. The only gasket available was $85.00, but it's a factory AC Delco part, so I have confidence it won't leak
I had to cut the back of the crossmember to access the oil filter and I degreased everything while I had it apart.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-29-2022, 08:24 PM   #206
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I mounted the driver's side for lights/turn signals. I can't find the other pair I had, so I'll order a new set.
-just
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-02-2022, 11:20 PM   #207
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I know a lot of things people say can be superstitious, but I swear every time I misplace something, the only way I find it is by getting a replacement. My replacement fog lights arrived today, and no sooner than I walked into the shop, I almost immediately found the set I was looking for. It's been that way with me as long as I can remember
I didn't get pictures of how I mounted the driver's side lights, so here's what I did. Since the inside of the bezel is shallower that the outside, the fog light hits the panel where the grille mounts, I drilled a hole and bent a section down to use as a mount tab for the inner lights. I used a section of radio strap for the driver's side light, but couldn't find any for the passenger side to mount the outer light to the bezel mount stud, so I found a city horn bracket and made that work. I cut a relief hole toward the bottom of the bezel to hide the wiring by passing it into the fender well.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-02-2022, 11:22 PM   #208
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Here's what they look like lit up.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-03-2022, 10:26 AM   #209
6DoF
6DoF's Avatar
Re: 1958 Saab story
dang, all the light
6DoF is offline   Reply With Quote
Old 02-05-2022, 02:29 PM   #210
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
So my headlights arrived and they were all black instead of the black and chrome I wanted, so those will have to wait. I decided to tackle the grille and bumper. I made a template so I know where to cut the teeth to fit to the bumper.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-05-2022, 07:43 PM   #211
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
A quick trip to tractor supply for some 5/16 hardware and strap bracket and I made all the bottom mounts to bolt the teeth to the bumper.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-05-2022, 07:45 PM   #212
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Now the teeth and bumper are one unit. I still have to secure the bracket to the frame, but this is what I ended up with.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-06-2022, 06:29 PM   #213
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I mounted the power steering cooler and then rolled it outside to get some daylight pictures of the stance and the new grille and bumper
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-07-2022, 09:43 AM   #214
6DoF
6DoF's Avatar
Re: 1958 Saab story
that came out sick sir, love seeing something different
Old 02-07-2022, 11:09 PM   #215
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
So I dug the back half of the original floor out of the scrap pile and made it skinny enough to slide through the back door. It'll be easier and faster to fill in the gaps and trim the back of the blue fender wells to maximize clearance to the air compressor and top shock bolts.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-08-2022, 02:24 PM   #216
6DoF
6DoF's Avatar
Re: 1958 Saab story
worth it
and the hidden cubby is kinda cool too
Old 02-10-2022, 01:40 AM   #217
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Before I start filling in the floor panel gaps, I need to locate the fuel filler neck. I've always wanted to do a hidden filler behind the tail light. Since this one is most important because of the limited real estate given by the size of the fuel cap door, it'll dictate where the passenger side lights will go to match up.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-10-2022, 09:56 AM   #218
dsraven
Re: 1958 Saab story
what will you use for lights back there? I was thinking of using lights from a chevy HHR or a chevy cobalt. maybe an old impala with th bullet lens but then I would always be replacing the lens due to somebody bumping into them or "needing" them.
are you planning to repaint the project when it's done? it looks to be in pretty good shape body wise. too bad you had to weld the gas door in, it seems you have been able to get away without disturbing the paint up till now. inevitable I guess.
question on the grill, does the upper ends of the "teeth" get a crossbar to hold them all together and keep their spacing? the bumper fits nice and tight like it was made for the truck.
Old 02-10-2022, 12:02 PM   #219
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
These are the lights I'm using. They're cool because I got a pair where the center LEDs are white for reverse lights, and another pair where they're amber for turn signals. I'll stack them with the amber lights on top and white ones below.
I am planning to repaint the truck when finished. I love the color blue that's on it, so I'll try to stay around that shade, but I also want to do blue flames on it too. As you can see by my fridge in the garage and my dad's 2005 Colorado, I can paint some pretty decent flames. When my dad bought the Colorado, he had a choice between red or black. He wanted me to put flames on it and they'd look better on the black one. It has 726 miles on it when I painted them.
Originally, the teeth mounted lower on the bumper, through the holes you can see in the center of the bumper and had a plate that kept them lined up that bolted to the bottom of the teeth. Now, the teeth mount across the bumper bar, and the bumper is bolted to the bottom of the teeth. And I put a carriage bolt on either end of the bumper, attaching it to the fender. That helps secure the bumper ends so they for with the lines of the front fender, and adds more rigidity to the front sheet metal.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-10-2022, 12:08 PM   #220
6DoF
6DoF's Avatar
Re: 1958 Saab story
Flap yeah dude
Old 02-10-2022, 11:48 PM   #221
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I cut the ends off the bumper support braces that go to the ends of the bumper and slid them inside frame to secure the front bumper.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-11-2022, 12:00 AM   #222
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
So, after cutting the outer skin off the fuel door, I had to make a reinforcement brace from the articulating arm to the edge of the lid to make clearance for the light. I repurposed the metal skin from the fuel door and triangulated a rigid support as best I could and then cut away the webbing and put a few more tack welds on it.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-11-2022, 12:02 AM   #223
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Here's the light just set in the hole so I could post pictures, but you get the idea. It turned out pretty nice, I think.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 02-11-2022, 08:54 AM   #224
Father&son56project
Re: 1958 Saab story
Clever fab work!
Father&son56project is offline   Reply With Quote
Old 02-11-2022, 10:52 AM   #225
youngrodder
youngrodder's Avatar
Re: 1958 Saab story
Very slick way to conceal the Gas hole....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
