#1 | |
Posted via Mobile Device |
Re: Hard Starting 350
Q-jets are a bit famous for leaking back since the inlet is on the bottom of the carb vs the top like a Holley.
I forget what it's called but there's a filter with a check valve that helps fix the problem. My friend had this problem so bad he went with a electric fuel pump. Even after a few attempts at repairs. His was a DD, and would leak back in as little as a hour. |
#3 | |
![]() Join Date: Jan 2011
Cheers, Nathan
70 Custom 10 350 w/700r4 (current) 69 Custom 10 I250 Three on the Tree 72 Cheyenne Super 350 66 Ford F100 I240 Three on the Tree 72 Chevelle Malibu 402 66 Pontiac Catalina 421 65 Ford Fairlane 500 |
I’m listening and considering all the responses. I failed to mention the last time it was started was about a week ago. It wouldn’t start so I replaced the inlet fuel filter. I didn’t know there was a second one until now. In any event it started and ran almost immediately. I let it warm then turned it off. It started immediately and continued to whenever I tried over the following few hours. That leads up to yesterday when I posted about my problem.
I’m attaching pictures as previously requested. Posted via Mobile Device |
Update: with the help of a 1- second spray of starting fluid Ingot it started, running and warm. It starts right up after sitting an hour or so. I’ve ordered the Quadrajet manual and am preparing to learn all about what I’m experiencing. Thanks for all the input.
