02-05-2022, 11:03 PM | #1 |
Shock alignment
I bought a new set of Monroe shocks for the 62. Has anyone had this Problem? Should I just force them into position or is there another issue?
02-05-2022, 11:16 PM | #2 |
Re: Shock alignment
What does the new shock look like next to the old one? Is the bottom bolt bent?
02-05-2022, 11:19 PM | #3 |
Re: Shock alignment
It didn't have shocks on it when I got the truck.
02-05-2022, 11:40 PM | #4 |
Re: Shock alignment
Looks like a 63-72 crossmember and control arms, is that the original '62 X-frame? Maybe the original '62 upper shock mounts? '63 up frames used a single stud on the frame rail to mount the upper shock, so it seems like someone crossmember swapped a '62 frame and the upper mount doesn't match up with the '63 up shock location.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-05-2022, 11:49 PM | #5 |
Re: Shock alignment
That is a 63 front cross member on the 62 X frame. It sounds like I will need to get new upper shock mounts. I am not sure how the original 62 shocks mounted. What are other front X member swaps using for the front shocks?
02-06-2022, 12:24 AM | #6 |
67-72 parts collector,…
Re: Shock alignment
Maybe add a set of these upper mounts from CPP.
02-06-2022, 12:47 AM | #7 |
Re: Shock alignment
It will look really out of wack because you are at full droop. The misalignment isn't anywhere near as bad sitting at ride height. Worry not.
I relocated mine, with a 2" pancake:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-06-2022, 01:57 AM | #8 |
Re: Shock alignment
thank you for the reply's. I will check out CCP upper mounts and I will also check the shock angle at ride height.
02-06-2022, 06:11 AM | #9 |
Re: Shock alignment
Or…
Check out post #42 on my build where I made a pair of shock relocation brackets from some box steel. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
02-06-2022, 07:35 AM | #10 |
Re: Shock alignment
Oh, I'll have to check that too, I have the same conversion. The 62 has the bolt on the lower control arm, the 63 has the pocket for the shock absorber
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
02-06-2022, 08:38 AM | #11 |
Who Me?
Re: Shock alignment
I moved my front shocks back a little when I bagged it.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-06-2022, 03:35 PM | #12 |
Re: Shock alignment
I used Porterbuilt that came with kit.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-08-2022, 02:15 PM | #13 |
Re: Shock alignment
In fact, the problem occurs to me too, I'll take up Paul Y solution, thanks
02-13-2022, 09:08 PM | #14 |
Re: Shock alignment
It looks like Skinny G was right. when I raised the A frame to ride height it lined up. My next question is should there be that much deflection through the travel?
02-13-2022, 10:13 PM | #15 |
Re: Shock alignment
It's not an ideal design, but it's worked for sixty years. You'll be alright.
