Old 03-25-2014, 12:42 PM   #1
Cowboy5
Cowboy5's Avatar
Brakes are sticking.
I have a 72 Chevy 4wd. I recently put on brake pads on the front. Well the pad on the drivers side was grabbing the rotor and not releasing the pressure. I have tried to bleed them off. I tried to bleed the proportioning valve. I am going to try and replace the caliper to see if that is the issue, but don't want to replace it and that not be the problem. Anyone have any suggestions.
And by the way I want to thank VetteVet for all the help. He is a very knowledgeable person when it comes to repairing motor vehicles. He helped me get all the lights working. And for me to do electrical is amazing. Thanks Dude.
Cowboy5 is offline   Reply With Quote
Old 03-25-2014, 12:57 PM   #2
geezer#99
geezer#99's Avatar
Re: Brakes are sticking.
Likely sticky caliper. Pull it off, squeeze the piston back gently with a big channel lock pliers, put the caliper back on and gently squeeze the pedal down. You might need to do that a couple times. Could save replacing the calipers.
Old 03-25-2014, 02:08 PM   #3
cdowns
cdowns's Avatar
make sure the caliper slides on the rails and is not all rusty and wont let the caliper slide in and out freely
Old 03-25-2014, 04:49 PM   #4
Wrenchbender Ret
It is very likely the hose on that side is swollen up on the inside blocking the return of the fluid.
Wrenchbender Ret is offline   Reply With Quote
Old 03-25-2014, 06:16 PM   #5
motorcritter
motorcritter's Avatar
Flush the brake fluid- you'd be a surprised at how nasty it can get! Check both calipers, for deterioration and/or sticking pistons, and if the hoses have cracking on the outer layer, they're probably starting to break down inside. Check the old pads and see if there's uneven/abnormal wear on them, right vs. left and inner vs outer. Old brake systems can get very ugly- the neglect can be dangerous. Good luck and don't skimp on brakes- no matter how much it costs to fix, it's still cheaper than using someone else's vehicle to stop with!
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 03-25-2014, 06:28 PM   #6
mgchevyparts
mgchevyparts's Avatar
All of the above
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 03-25-2014, 07:00 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
last time i had that problem it was the hose
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-25-2014, 07:08 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I put my money on the hoses. If they're original, they're 42 years old. They swell shut internally and hold pressure on the caliper.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-25-2014, 10:39 PM   #9
Cowboy5
Cowboy5's Avatar
Cool Re: Brakes are sticking.
Thanks everyone never even occurred to me to check the hose. The caliper on the passenger side is OK but the drivers side the piston goes out but don't go back in. I think i will just replace it all just to be on the safe side. LMC is going to be really happy when i call.
Old 03-25-2014, 11:40 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
Local parts store should have what you need.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-26-2014, 08:56 AM   #11
Tx Firefighter
....or Rockauto.
LMC is quite over priced on things that you can get through normal parts channels.
Old 03-26-2014, 09:56 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I googled your problem and there are lots of videos on brake calipers.
Here is one of the best.
http://www.youtube.com/watch?feature...UqTgYgd0Mk#t=4
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-26-2014, 12:34 PM   #13
Cape Codder
Cape Codder's Avatar
Sometimes when you put new pads on the piston is further in the bore than it has been. If the inner part of the bore has crude it can stick, especially with alluminum calipers used on some cars. I now just lightly pump the brake with the caliper off the spindle and pads out till the piston pops out. Clean and sand the piston and bore with 1000 grit paper lube with clean fluid and push it back in. As long as the seal is good and it doesn't leak you have just done what a rebuilder does. Change the fluid when done.
Cape Codder is offline   Reply With Quote
Old 03-26-2014, 10:28 PM   #14
dbelanger24
dbelanger24's Avatar
great info on rebuilding the piston yourself. And with my experience RockAuto is always cheaper and carry a wealth of parts.
haven't started a build yet but counting the days until I do! t-2years!
dbelanger24 is offline   Reply With Quote
Old 03-28-2014, 05:36 PM   #15
Cowboy5
Cowboy5's Avatar
can i use the hoses and calipers off any later year chevy 4x4
Old 03-30-2014, 01:55 PM   #16
Cowboy5
Cowboy5's Avatar
Well brakes fixed everyone. Brake caliper was only 17.00 at AutoZone so why not. Works good now thanks for all the good advice.
Old 02-18-2022, 08:45 PM   #17
slikside
slikside's Avatar
Old thread, I know. But I have a similar situation, only mine is rear drum:
Rear brakes dragging after backing down sloped driveway, and still drag for some time there after...
Full brake system resto 11 years ago. from pedal to pads. Vacuum booster and MC were overhauled, new brake lines installed. Front calipers rebuilt. All new drum hardware and wheel cylinders installed. New hoses all around.
Haven't changed the fluid since. Waaay overdue for that I know. System has worked fine until this dragging issue.
My question: Could a brake fluid flush alone possibly correct this problem?
I know hoses can swell on the inside and not release the pressure, so if I start guessing at what parts to replace, the rear hose would be my first option, but I'd rather not guess at all. Thinking of flushing first and going from there. What'ya think?
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 02-18-2022, 09:58 PM   #18
HO455
HO455's Avatar
When you are sure the brake is dragging loosen the bleeder. If you get fluid spraying out under pressure then the hose is bad and it is trapping pressure in the line.
If the fluid just oozes out then something mechanical is keeping the shoes applied.
It is unlikely a brake fluid flush would fix this or if it helped it wouldn't be a permanent fix. Flushing the fluid is preventive maintenance not corrective maintenance.
Good luck and I hope my opinions will help you.
RIP Bob Parks.
Old 02-18-2022, 10:45 PM   #19
slikside
slikside's Avatar
Thanks, HO455. That's a great idea. I'll give that a shot first!
Probably just wishful thinking on my part that a brake flush would do the trick. But that will also get done before this is wrapped up.
Thanks again!
Old 02-18-2022, 11:15 PM   #20
LockDoc
The Older Generation
LockDoc's Avatar
If you don't drive it much and the system has some moisture in it the wheel cylinders will rust inside and start to seize up.
LockDoc
Leon
Old 02-18-2022, 11:29 PM   #21
slikside
slikside's Avatar
LockDoc
Makes sense, and a real possibility, as I don't drive it often. Thanks Leon!
