Old 09-03-2020, 12:10 AM   #1
rechinca
rechinca's Avatar
Installing inner cowl
As I get ready to install the complete inner cowl (this so far has been a learning experience), I have come across a couple of questions. After I get my plug welds done and the piece installed, do I need to or at least should I add seam sealer along the top edge? I don’t recall there being any from the factory, but it could be a reason they had rust in that area. Anyone else have experience with this repair and suggestions or thoughts?
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 09-04-2020, 09:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Installing inner cowl
I would use some in that area. It would be cheap insurance against leaks.
LockDoc
Leon
Old 09-04-2020, 11:22 PM   #3
rechinca
rechinca's Avatar
Thanks Leon! Bought some 3M heavy bodied sealer as I will be doing the drip rails too before we get rain. Figured I’d just stock up!
Old 09-05-2020, 10:51 AM   #4
LockDoc
LockDoc's Avatar
That should work.
LockDoc
Leon
Old 09-05-2020, 08:07 PM   #5
72c20customcamper
72c20customcamper's Avatar
Seal all the seams. And when you think your good to go, go over it again . I used single stage polyurethane on my cowl and brushed it in good and used the 3m high build self leveling on the 68s drip rail
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-19-2022, 10:59 PM   #6
cj847
cj847's Avatar
I am trying to understand the sealing process for my cowl leaks on both sides. The main leaks are where the inner cowl meets the A pillar. I have cut an opening in the upper cowl so that I can get to this area. It does appear there was factory seam sealer there that has failed. I am guessing the issue was the "diverter" probably got clogged with leaves/debris 30 years ago keeping the area wet and funky. One of the leaks is at the joint of inner cowl, A pillar, and "diverter".
My question while contemplating the mess under my dash was what about the firewall to inner cowl? I don't see any evidence of seam sealer across this long seam. However, it appears obvious that it needs to be sealed.
What say you experts?
cj847 is offline   Reply With Quote
Old 02-19-2022, 11:47 PM   #7
LockDoc
LockDoc's Avatar
My answer would be the same as I recommended in post #2...
LockDoc
Leon
Old 02-20-2022, 09:13 PM   #8
toolboxchev
I am no expert, yet with a leaking window covered by a tarp I can tell you this. If you plan to repair this area PROPERLY it is time to tear the truck apart and do a complete cab repair to get it fixed right the first time. I have seen many pictures of failures in cab repair.
toolboxchev is offline   Reply With Quote
Old 02-22-2022, 02:40 PM   #9
bry593
Respect if you are doing inner cowl. That's a job.
Just so you know, the Loctite PL Roof and Flashing (Black polyurethane from Home Depot), works well for this application. Costs $8 a tube and is typically on the shelf.....
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 02-23-2022, 02:04 AM   #10
Impact02
Impact02's Avatar
You could also use panel bond and it will attach it and seal it all at one time
Impact02 is offline   Reply With Quote
Old 02-25-2022, 02:46 PM   #11
dz1087
I went to town with the 3M panel adhesive all over my weld areas in inner/outer cowl area. Didn't use the self leveling since it is really runny while setting up. That stuff did work like a champ on the drip rail, though.
dz1087 is offline   Reply With Quote
