All about them K’s
![]() Join Date: Jun 2014
Re: 1967 Axle Swap
Here’s a thread that is active right now that should help you out. The front shouldn’t be a problem but you will probably have to add power steering to your k10 to make the drag link work with the new axle. I would swap the whole axle assembly over. Individual parts from one axle to another isn’t going to work with the closed knuckle assembly on the 67.
http://67-72chevytrucks.com/vboard/s...d.php?t=831067 This will give you an idea what’s involved.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
| Bookmarks |
