02-08-2022, 09:27 PM | #1 |
Dual battery setup
My ‘72 K5 currently has 2 yellow-top Optima batteries that are getting pretty tired. I previously had standard group 31 batteries and was happy with them. Then I lucked into these Optimas and have had them quite a while.
Of the 4 Optimas available, what combination would you use and why? I have 2 batteries because of lights and stereo demand and hopefully, someday, a winch. Or should I go back to the cheaper and more common big rig batteries? Thanks in advance.
'72 K5, known as 'the Fox.' Last edited by mister.freeze; 02-08-2022 at 09:28 PM. Reason: Spelling |
02-08-2022, 11:21 PM | #2 |
Re: Dual battery setup
I am a big a fan of the Optima batteries but probably won’t be buying more as they are just too much $$$$. As they age out, I have been replacing them with Duracell AGM marine batteries from Sam’s. Current price is $125 each. I am NOT a fan of side terminal connections so my trucks have been re-wired with welding cable and copper lugs. I like the screw terminal connections on the tops of the batteries along with the standard top post.
02-14-2022, 12:18 AM | #3 |
I'm in the same boat, adding aux battery and winch to my K10. I was planning to use a deep cycle marine battery in the auxiliary position to run lights and chargers in my camper shell, but I'm concerned that a constant voltage charge from the vehicle electrical system would shorten the battery life. Anyone here have experience with deep cycle batteries?
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
02-19-2022, 06:16 PM | #4 |
not a lot of responses. One reason I like the optimas is that they couldn't 'boil out' from constant charging like generic lead-acid batteries. The suggestion of AGM batteries is good, but I though optimas were AGM. The question at hand, though, is about the combination of battery types for best performance.
'72 K5, known as 'the Fox.' |
02-20-2022, 03:47 PM | #5 |
Optimas are not as good as people think. I have one here (red top) less than a year old that wont keep a charge.
Using deep cycle batteries is not a good option either. They are designed to be slowly discharged then recharged and can handle constant 50% drops. This is the opposite of what you want in a truck/car battery. A car battery is designed to have a high load applied to it (starting) then recharged immediately. Unfortunately, most batteries suck today so it's a luck of the draw if one will last 5 years or not. If I had to have a dual battery setup for stereos and such, I would use one conventional battery for starting, then I would use a deep cycle for the accessories but I would isolate this battery so it doesn't get used for starting the truck. RVs use this type of isolator for that exact reason. Last edited by hemi43; 02-20-2022 at 03:56 PM. |
02-20-2022, 07:21 PM | #6 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I installed a Hellroaring Battery Isolator in my 71 Blazer back in 2000.
Model # BIC-7300A $189.90 back then but I bought the in-cab remote module as well. New part # is BIC-95300A https://www.hellroaring.com/products.php I had a red and Yellow top Ultima batteries. Red was my starting and vehicle 12V POS supply and the yellow was a backup. I have a Warn 9000 winch and wanted the 2nd battery for that. It's still working well today. The Optima's crapped out in about 3 years though. I use it in conjunction with a remote starter solenoid. Here's a pic.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 02-20-2022 at 07:27 PM. |
