Old 02-20-2022, 07:58 PM   #1
71gmcC15
71gmcC15's Avatar
Headlights don't work and it's not the dimmer swich.
Like the title said. Dimmer swich is new and the wires are in good shape. The problem. I got home and and turned the hi beams on because I wanted to see what they looked like at night. Headlights when dark. Spamed the dimmer swich got them to come back on. Then hit to go back to lows the whent out and they never came back on. All other lights work. This happed before with the old dimmer To. I could aways get them back but now I can't. I checked fuses to see thare is no fuse. I have power going in and out of the dimmer but no power to the headlights. Got any suggestions.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 02-20-2022, 08:38 PM   #2
truckster
truckster's Avatar
Re: Headlights don't work and it's not the dimmer swich.
Check the terminals. A lot of dirt gets down there.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-20-2022, 09:08 PM   #3
71gmcC15
71gmcC15's Avatar
It's all clean.when I put the new dimmer in I put new connections on it to.
Old 02-20-2022, 09:14 PM   #4
Accelo
Accelo's Avatar
https://www.youtube.com/watch?v=Tlzdq2nVCcE
Good video on how the Head Light switch works. Maybe it will help.
Accelo is offline   Reply With Quote
Old 02-20-2022, 09:44 PM   #5
71gmcC15
71gmcC15's Avatar
I got power at the dimmer so the headlight swich is working. Great that makes it harder. Must be a under hood issue. I'll take the bolk head connector off the fire wall see if I got Power coming out. If I do then it's a problem between the headlights and the bulk head connector. ( broken wire? )
Old 02-20-2022, 10:40 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
If that checks out OK it may be a bad ground to the core support. Run a wire from the battery ground post to a cleaned bolt on the core support.
LockDoc
Leon
Old 02-21-2022, 12:40 PM   #7
dmjlambert
dmjlambert's Avatar
It may be a good idea to check the headlight bulbs to make sure they didn't burn out, just carefully connect the lugs directly to power using some test wires with alligator clips.
Old 02-21-2022, 12:43 PM   #8
kwmech
Now-a-days just because the switch is new doesn't mean it's not bad or it didn't break internally first time out. Power comes in at the top of the switch and low or high beam come out the sides at the bottom.
Old 02-21-2022, 01:49 PM   #9
jimijam00
$5 says its the switch
jimijam00 is offline   Reply With Quote
Old 02-21-2022, 02:18 PM   #10
71gmcC15
71gmcC15's Avatar
LockDoc
I don't have power at the light socket. And if the ground was bad my side markers would aslo not work. Thare aftermarket led 3 wire. I grounded them to the same spot as the headlights. When it gets nice out again hopefully this weekend I'll check the bulk head connector
Old 02-21-2022, 02:22 PM   #11
71gmcC15
71gmcC15's Avatar
I hope your right. I'm going to jump the wired together by passing the swich to see if that fixes it.
Old 02-21-2022, 02:44 PM   #12
rockyrivermark
electric issues are a process of elimination and easy when you think methodically. Don't just buy a bunch of parts and throw it at the problem.
get a probe light tester and check for power at the socket. If you have power at the socket then fix ground issue.
if no power at socket then test backwards towards the power source, Ex. in and out of the switch.
if no power at switch test back to fuses and power supply.
eventually it will lead you to the problem.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 02-21-2022, 07:10 PM   #13
71gmcC15
71gmcC15's Avatar
Dont have power at the socket. Have power at the dimmer. So headlight swich is good. Bulbs are not burned out. Thare is no fuse. If it was bad ground my sidemarkes would not work either. Thare tide into the same ground as headlights. High beam indicater still works ti so the dimmer is switching the power like its sappose to. The problem is between the light socket and dimmer swich. I haven't bought any parts yet. To poor for that. When it get nicer out above 20F I'll dig deeper. But now it's not worth freezing.
Old 02-21-2022, 08:40 PM   #14
71gmcC15
71gmcC15's Avatar
Update. Made a quick bypass harness for the dimmer switch. It is not the dimmer. I can send power to the low beam and I here a relay click no lights. Try the hi relay click indicater lights up no hi beam. Is the relay bad? Or what? Agin no power at the socket not a ground issue. It's a power issue.
Old 02-21-2022, 09:00 PM   #15
dmjlambert
dmjlambert's Avatar
Are you saying you hear a relay clicking? There is no relay in the stock system.
Old 02-21-2022, 09:16 PM   #16
rockyrivermark
Bypass the old wire and run new wire from the dimmer
My build page
Old 02-21-2022, 09:31 PM   #17
71gmcC15
71gmcC15's Avatar
That's what it sounds like. Under the dash. ( maby a circuit breaker)I do have a HD headlight harness with relays on the core sapport. but I've experienced this before I installed it. Always got them to come back on. But now they dont Gess I could try hooking the lights up factory and see what happens.
Old 02-21-2022, 11:02 PM   #18
Mike C
Mike C's Avatar
The headlight switch has a circuit breaker built into into it. I read the whole thread once but am not looking back, have you replaced the headlight switch?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-21-2022, 11:46 PM   #19
BigBird05
If you are running a relay do you have power into and out of the relay? What is your power source into the relay?
BigBird05 is offline   Reply With Quote
Old 02-21-2022, 11:49 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you can hear a relay click and since you have eliminated some other areas, take a good look at your relay(s). Some relays have built-in blade fuses that might be bad.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-22-2022, 12:19 AM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
It would appear that there is something downstream out of order. You are correct about the headlight switch having a breaker on it. I'm interested on seeing where this goes, in terms of the final repair.
~Steven
Simi Valley, CA
Old 02-22-2022, 07:15 AM   #22
71gmcC15
71gmcC15's Avatar
I have not replaced the headlight switch
Old 02-22-2022, 07:20 AM   #23
71gmcC15
71gmcC15's Avatar
I will have to check. To see if power is coming out of the relays. I know power is going in. Fuses is good and is hooked straight to battery. Then the relay gets. triggered by the factory wiring to swich between hi and low beam. But the thing is it's done this before I ever installed the HD harness. But was always able to get them back. The only reason I installed the harness is because the dimmer would get so hot and melt the terminals. Maby it damaged the headlight swich to and now it Finlay gave out?. As in it sends power to the dimmer but the circuit braker tripes and doent send power out to to headlights idk. I'll check the relays when I get a chance though.
Old 02-22-2022, 07:48 AM   #24
BigBird05
If the dimmer gets that hot, you have to big of a power draw. Can you draw a schematic of how you have your relays wired?
Old 02-22-2022, 11:50 AM   #25
71gmcC15
71gmcC15's Avatar
It doent get hot anymore with the relay kit. It's basically the same thing as the lmc harness but actually works.
