Old 07-24-2004, 07:10 AM   #1
charles oliver
68 camtruck
charles oliver's Avatar
Ignition Problems
Just wanting to make sure I am on the right path. Went out this morning to start the Jimmy and the Starter wanted to stay running when I turned the key loose.
Could this be the ignition switch or a starter problem ?
Thanks for any suggestions
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 07-24-2004, 07:16 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Is this an intermittant problem or did it just start happening?
How did you stop it from cranking over?
It's most likey and ign. prob. as there is nothing else in the circiut that controlls power to the solenoid.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 07-24-2004, 07:31 AM   #3
charles oliver
68 camtruck
Ignition Problems
It just happened. I drove it a week ago and it was fine. I stopped it by turning the key off.
Charlie
71 GMC Jimmy 4X4
Old 07-24-2004, 07:43 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
sounds to me like the ign sw. getting worn out & making contact with purple wire. keep in mind I have also seen the starter sol. cause this too. rare but has happened.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-24-2004, 07:46 AM   #5
vtblazer
vtblazer's Avatar
I had the same issue once but I had wired the solonoid (sp?) wrong. I had to swap the two wires around but being this is a new symptom I'd go with the cylinder or a connection that goes to it. Check the plug, I had one once that the p/o had used crimp-on connectors to the back of the key switch looked like trouble waiting to happen...had to change out the whole harness for that one.
Good luck...
vtblazer is offline   Reply With Quote
Old 07-24-2004, 10:21 AM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
I had a problem just like yours and I traced the problem to the ignition switch. The ignition switch needed to be lubed, so I removed it and I sprayed it with WD40.
A.P. is offline   Reply With Quote
Old 07-26-2004, 07:32 AM   #7
charles oliver
68 camtruck
Ignition Problems
Thanks for all the suggestions. It was the ignition switch. I replaced it and it is fine now.
Charlie
Charlie
71 GMC Jimmy 4X4
Old 07-26-2004, 10:43 AM   #8
big blue 72
Charles, are you interested in going to the Ohio Meet In September? Pm me for details on the Cincy area caravan.
thanks Big Blue 72
big blue 72 is offline   Reply With Quote
