Old 02-21-2022, 04:38 PM   #1
MARKDTN
'73 Power brake upgrade-booster?
I inherited a '73 LWB plain truck. (originally thought it was a '74 but it's a '73) It's been sitting for roughly 15 years and the master cylinder is bad. I want to upgrade to power brakes. What booster can I use? Any square body? 73-74 only? I can deal with lines and vacuum and all that, just curious what booster I can use.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-21-2022, 07:06 PM   #2
ltdmstr
ltdmstr's Avatar
Re: '73 Power brake upgrade-booster?
I'm a big fan of hydroboost. I have a '68 that was manual steering and manual brakes. Added ps, front discs and hydroboost and it's like a completely different truck Brakes are outstanding.
ltdmstr is offline   Reply With Quote
Old 02-21-2022, 08:20 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
Hey if you don’t feel like worrying about all that brake stuff, I’m happy to come down there and take the truck off your hands. Haha.
But, x2, hydro boost is awesome. You can find them in any factory Chevy/GMC diesel truck from 78-87 and of course the 88-91 burbs/blazers.
Old 02-22-2022, 08:54 AM   #4
MARKDTN
Appreciate the advice, but I am not a Hydroboost fan. Actually the same company that originally owned this truck before my uncle had an early 80s C30 with Hydroboost and it spit fluid all over the interior more than once. I think I will stick with vacuum. So can I use any square body booster or is it 73-74 only?
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 02-22-2022, 02:12 PM   #5
ltdmstr
ltdmstr's Avatar
That's pretty strange. If a line broke I could see how it would make a mess of the engine compartment. But I have no idea how the fluid could get to the interior. The only thing on the inside is the rod going through the firewall
Old 02-22-2022, 05:12 PM   #6
MARKDTN
Very common issue back in the day. The seals on the rod leak and there were no rebuild kits available. I'm sure they are better than they used to be but this truck is going to be very stock. I don't want to have to source new lines etc. I just want to put a booster and new master cylinder. I just don't know what fits. If you look at applications on '73 boosters, many show '73-'74 but I don't see why it wouldn't work on '73-'87? Surely somebody has added a power vacuum booster on a manual brake '73-74 before.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 02-25-2022, 07:46 PM   #7
69Tom
In case you want to double check what you're buying, there were 2 boosters used in 73-74. Moraine, PN 2620594, and Bendix, PN 6259004. Maybe just check out the rebuilt boosters? RockAuto has one for $95 and that's with the core charge.
Also, I assumed that's a C10, but if it's a C20, there was one booster: Moraine 2620595.
69Tom is offline   Reply With Quote
Old 02-25-2022, 11:50 PM   #8
HOTFUN
HOTFUN's Avatar
69Tom
I can't find reference to the Bendix PN 6259004 in the GM book as it does show for 73-74 CK-1 cab, Blazer use Bendix PN 346401. May be my GM book is printed later than yours as mine is 2/85?
Do you see an application reference for the 6259004 for 73-74 CK1 cabs?
Thanks, Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 02-27-2022, 06:13 PM   #9
69Tom
Originally Posted by HOTFUN View Post
69Tom
Thanks, Mark
Hey Mark. Those numbers are from an actual 73-74 parts book. So if I had to guess, the number you are seeing supersedes the numbers I posted.
Old 02-27-2022, 07:17 PM   #10
Dead Parrot
Might want to double check if the brake pedal needs replaced/modified. Some vehicles had the manual brake post for the MC push rod in a different spot then the post for a power brake setup.
Dead Parrot is offline   Reply With Quote
Old 02-28-2022, 11:45 AM   #11
Factory Guy
Factory Guy's Avatar
I am with you on the vacuum Brake booster. Mine stops great, its a 1973 C2500 GMC 3/4 ton Camper Special. Since this was a little heavier duty set up, my vacuum booster may to be the same. But it will put you through the windshield if you stand on the brakes and this truck is NOT light. Mine is all original right at 100,000 miles on the odo.
Sorry it keeps rotating the picture 90 degrees.
Factory Guy is offline   Reply With Quote
Old 03-01-2022, 10:06 AM   #12
MARKDTN
There are a whole lot more 75-87 trucks out there than 73-74-most with power brakes. I was hoping to find somebody to say, "yes, any square body booster will work on a 73-74 if you do XYZ". Or maybe "yes, 73-82 all bolt up to the firewall but the master cylinder is different". Or something like that. Maybe I have to have a power brake pedal? I know that I can buy a 73-74 booster from Ebay or Rock Auto, but I think I can find used for much less. I'm not worried about the fittings on the master cylinder; I have a Mastercool tool and can make new lines if necessary. I'm just trying to find out what vacuum booster will physically bolt on to a '73 without cutting new holes in the firewall or pedal support bracket. Then I can hit up friends and junkyards and find one. I will buy a new master cylinder, but I can't do that until I get a booster just in case they have a different bolt pattern. Thanks!
'83 K20-TPI
'73 C10
'14 Suburban-DD
