Originally Posted by MikeB
I went through hoses from several "manufacturers" only to find the bends were almost identical and nowhere near OE. Ended up using a tubing bender to allow the tubes to clear the frame. My pressure hose was a very tight fit and needed persuasion to get it at the correct angle to connect to the pump.
If I had a do-over, I might bite the bullet and use braided hoses with flare to -AN adapters.
Stainless w/-AN adaptors wouldn't fit in my case.. Not much room at the rear of the pump, the headers were in the way. The irony of the ordeal was that I didn't like the way the headers fit overall, they interfered with everything.. Several months after the power steering install, I finally removed them and refitted cast iron exhaust manifolds... I don't have any pics of the final install.
Here's a link to some illustrations of the hose I used. It crosses the frame in front of the pump, drops down and runs under the pump. Then straight up to the pump pressure fitting.
https://www.bing.com/search?q=edl-70...ANAB01&PC=LCTS
