Old 02-26-2022, 01:58 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
HELP. 1Wire to solenoid , what color
My Sons Truck only has 1 terminal at the solenoid plus the bat cable. What color wire goes to the solenoid Yellow or Purple???
The only thing I know about electricity is , You can’t see it and It Will Kill You, so I Don’t play with it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-26-2022, 02:15 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: HELP. 1Wire to solenoid , what color
Purple wire goes to the "S" terminal. The yellow wire provides ignition power during cranking. If he has electronic ignition, the yellow wire is vestigial.
~Steven
Simi Valley, CA
Old 02-26-2022, 02:52 PM   #3
1970 CST Short Wide
Senior Moment
vestigial ???? Yes he has HEI
Pittsburg Ca
94565
Old 02-26-2022, 03:22 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
That's what I said too...??.. I'm too lazy to look it up..
The yellow wire is not needed if he has the HEI. Purple wire goes to the small terminal. ("S" for solenoid)
LockDoc
Leon
Old 02-26-2022, 06:35 PM   #5
RichardJ
It isn't an issue of not being used with an HEI ignition. It is more of a matter that it should not be used with an HEI.
The "R" terminal (sometimes labeled as "I" terminal) connects to a little bent copper finger inside the solenoid cap. The finger should contact the solenoid Disc, only when the solenoid is energized.
The solenoid contains two coils. A Hold-in winding and a Pull-in winding and both generate a large magnetic field when energized. When the 12v is removed from the "S" terminal, the magnetic field collapses and a very high EMF, voltage spike is generated across the coils.
If the solenoid disc flops the wrong way and/or the copper finger is bent incorrectly, that High voltage spike can travel up that yellow wire and fry the HEI module.
With the old points ignition, a high voltage spike from the solenoid, applied to the ignition coil would go completely unnoticed. It's busy generating its own voltage spike.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-26-2022, 11:48 PM   #6
1970 CST Short Wide
Senior Moment
It was the Purple wire. The reason we didn’t have power to it was that it runs through the neutral safety switch. We had changed the column to standard from Auto (going with 4 speed) so the NSS needed to be jumped. Problem solved
Pittsburg Ca
94565
Old 02-27-2022, 06:06 PM   #7
dmjlambert
dmjlambert's Avatar
So now the neutral safety switch is vestigial!
Old 02-27-2022, 08:08 PM   #8
1970 CST Short Wide
Senior Moment
Pittsburg Ca
94565
Old 02-28-2022, 09:32 AM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I look it up, weird word but it fits ....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
