Old 02-23-2022, 09:59 AM   #1
Ziegelsteinfaust
Computers
When does a gen4 computer become needed vs a gen3 version?
I am going to build a 5.7 LS engine, and I can get a gen3 cheap + complete.
Main goal is 450hp crank NA or maybe a turbo or supercharger for 525hp.
At these power levels does the gen4 version work alot better? Or what is it better at, or is it only better when pushed harder?
Ziegelsteinfaust is offline   Reply With Quote
Old 02-23-2022, 01:45 PM   #2
jessemthompson
Re: Computers
LS1 is gen3. You’ll need a gen 3 computer. You would have to change out to a 58x reluctor wheel for the crank, the knock sensors, the cam position sensor etc to use a gen 4 setup. There really isn’t an advantage to gen 4 over gen 3. The gen 3 has a pcm, the gen 4, an ecm and TCM.
jessemthompson is offline   Reply With Quote
Old 02-23-2022, 01:54 PM   #3
Ziegelsteinfaust
Re: Computers
Is there any advantage to the gen4 computer?
I get the gen3 is cleaner, and good enough for what I want.
Old 02-23-2022, 06:06 PM   #4
LS short box
Re: Computers
One of the good things about the gen 3 ecm is that its controls the engine and auto trans. The gen needs two ecm's one for the engine one for the auto trans.
Old 02-23-2022, 07:49 PM   #5
bigmoe
bigmoe's Avatar
Re: Computers
Just aesthetics but the Gen IV box and plugs are physically smaller.
bigmoe is offline   Reply With Quote
Old 02-24-2022, 09:31 AM   #6
Joyridin
Re: Computers
The Gen 3 is generally easier to tune if you are a novice and plan on messing with it yourself. The Gen 4 uses a lot of algorithms to control certain functions whereas the Gen 3 has tables. You can find tons of info on tuning a Gen 3. Gen 4 is a bit harder. As stated, you would have to buy a converter box to run a Gen 4 computer on a Gen 3 or change the reluctor wheel on the engine.
Joyridin is offline   Reply With Quote
Old 02-24-2022, 10:59 AM   #7
Ziegelsteinfaust
Re: Computers
Gen3 easier to tune for the novice.
Is there any advantage to gen4 tables?
I haven't bought parts yet, but I plan to start soon. So I want keep everything from the same gen.
Old 02-28-2022, 11:10 AM   #8
71cadc10
71cadc10's Avatar
Re: Computers
only advantages to the GenIV tables I can think of off the top of my head:
flex fuel if you want to run E85 and have the computer handle it
drive by wire throttle body instead of cable operated (this might make cruise control integration easier? I have GenIV system in my truck but haven't messed with setting up cruise so I'm unsure).
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 02-28-2022, 12:02 PM   #9
Ziegelsteinfaust
Re: Computers
I am not interested in cruise control particularly.
Is DBC easier to install the DBW?
Old 02-28-2022, 06:01 PM   #10
LS short box
Re: Computers
I've used both DBW and DBC on my LS swaps with very good success.
The nice part about a DBC is you can with the hood open and the engine running you can move the throttle. With DBW you have to use the throttle pedal.
On the later DBW systems you don't need the tac? box.
