![]() Join Date: Dec 2014
GMC Grill Interchangability
Quick, silly question. Can I put a 67 GMC grill in a 72 without any fuss or hassle?
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
![]() Join Date: Sep 2007
Re: GMC Grill Interchangability
youd have to change the grill top bar i believe
1967custom |
Thanks, appreciate the info.
Yes, you can swap any 67-72 grille between years. All grilles fit exactly the same. The only differences are between the 67/68 top bar and 69-72 top bar. This difference goes hand in hand with the hood differences between the same years. The top bar is a separate part from the grille that is attached by rivets. Drill those out and you can use a 67/68 grille with the 69-72 top bar (center grille surround) and vice versa
Thanks! That is some valuable information… since I was thinking of ALSO using my 1967 hood. So do you think I’d have any problem using the pair?
That'll work. There is a difference between 67/68 hood latches and 69-72, same as hoods, on both Chevy and GMC. I'm not sure if that matters or not. The difference is where it bumps up in the front the 67/68s are sloped more while the 69-72s are steeper, just like the hoods. It's a really minor difference mostly detectable when compared side by side. I don't think that contour matters, but never tested it to see if it matters
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 Last edited by special-K; 03-02-2022 at 10:41 PM. |
![]() ![]() Join Date: Jul 2002
Should work as the GMC fenders are the same 67-72 unlike the chevy. Well other than 67 had no side markers. I am not positive, but I think the hood release is the same for all GMCs also, but I don't remember for sure.
![]() Join Date: Jun 2002
Hood release is different from 67-68 and 69-72 GMC's
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
| Bookmarks |
