Bypassing ignition switch
Can anyone instruct me on how to bypass the ignition switch of a pre-emission HEI ignition system? I have a 1970 Chevy C 20 pick up which has had the engine replaced with a non-pollution controlled 350 Chevy with an HEI ignition system. Previous owner re-wired the ignition system with a toggle switch on the dash in a doorbell under the steering column to start the motor. Naturally they use all red wire and with my limited vision I am having a hard time getting the truck started. Any help would be greatly appreciated.
Thanks, DNBG Posted via Mobile Device |
#2 | |
Re: Bypassing ignition switch
![]() Join Date: Aug 2019
Rusty pile I think you are reading to much into it. I believe he means the PO added a door bell starter button.
No offense, but considering there's a doorbell under your column... who knows what kind of goofy rats' nest may be under there. It would be hard with pictures, and impossible without to troubleshoot someone's random wiring job.
Start with the basics. Grab one of the well detailed schematics here on this site. figure out how they're getting power to the HEI, and if the doorbell is work-around external wiring, or tied into the factory harness. If the HEI is hooked up using the original points wiring, there'll be additional work involved replacing that specific wire. The more information you give, the better equipped the board is to help you. Welcome, btw, and good luck figuring this out! |
#5 | |
And while we're criticizing.. It appears to me you didn't read enough of his post or mine.
![]() ![]() Join Date: Jan 2005
Here's the recommended way to power an HEI distributor in a 67-72 truck (uses the factory ignition switch):
https://67-72chevytrucks.com/vboard/...d.php?t=708975 |
Hey DNBG, Welcome aboard. Wish I was a bit closer to ya. I'd swing by and give it a quick look, and some ideas. Good link pjmoreland gave here. Hopefully one of our members might swing by and check it out. Always fun to talk truck with a fellow gearhead!
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I'm betting that someone is close by to provide some help. I'm about 50 miles away. I'd estimate that there is about 8 hours labor in it. Are you willing to pay that, in beer? Something like Bud, not Schaeffer,
![]() Join Date: Dec 1999
Ignition seems to already be bypassed. Appears to be not working. A little unclear. Want to just get working or put back to a stock keyed ignition? No idea what was done so this may be somewhat difficult.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Thanks for your concern. Having said that, it’s Damn Near Blind Guy, not Damn Near Stupid Guy. I do not intend to operate this vehicle by bypassing the ignition switch. All I wanna do is start the engine once to verify that it actually runs before I pull it from the truck prior to painting. I don’t want to re-wire the truck just to start the engine only to have to paint around a newly installed wiring harness. The engine turns over just fine. It just doesn’t have any spark.
So, if there’s anyone out there that can help me, great. Otherwise I’ll figure it out on my own. Thanks, DNBG Posted via Mobile Device |
#12 | |
Module looks like this. https://www.holley.com/products/igni...ts/parts/35361 Another alternative is just getting another hei. Like this. https://www.ebay.com/itm/39311137517...wAAOSwNTdiHnK3 Last edited by geezer#99; 03-02-2022 at 02:46 PM. |
First of all, thanks guys for all of your help and support.
In hindsight, I probably should’ve provided more information, but wanted to keep it simple. Clearly, the ignition switch has been bypassed with the aforementioned toggle switch and doorbell button. The toggle switch to supposedly provide fire and the doorbell to spend the motor. As I don’t have any fire, clearly there’s something wrong with the toggle switch/ignition system. All I wanna do is run a wire from the battery to the distributor and then crank the motor to see if it starts. So with that in mind, … Thanks,“Yuccales”, for your helpful tip. Now all I need to do is identify which terminal is the BAT terminal on the distributor. I believe it is an OEM HEI distributor, but I’m not 100% sure. “Steeveedee”, Considering that all I wanna do is run a wire from the battery for the distributor, I think eight hours is a bit much. Having said that, I wouldn’t mind having some help and would be more than willing to provide you with a beer of your choice. Just pick your poison. Having said that, it seems like a long way to drive to connect the wire. And having said that, I’ll probably made some help actually getting it running. It’s been turned over on a regular basis, but it hasn’t actually run in several years. At least as far as I know. So, again, thanks guys for all your help. Couple more questions… Can you upload pictures to this forum? And is there a way to DM someone on this forum? I’d like to contact some of you personally, but don’t wanna asked to leave personal information on this forum or provide my own. Unless I absolutely have to. Thanks again, DNBG Posted via Mobile Device |
#14 | |
I wouldn't want to drink and drive; those days are gone for me. I usually fall asleep...
#15 |
The answer is yes, but it can be confusing. The text box I am using to replay doesn't the link to add pictures from your computer. Only from a hosting service. If you start a New Thread the link is there by default. (It is the paper clip looking icon) After the first post all other posts come up with an abbreviated form without the link. However, it is accessible if you hit the GO Advanced button just below the text box. When you do that, it brings up the same text box you get when you start a New Thread. Once you get this far you are not finished. Clicking the paper clip looking icon brings up a standard Manage Attachments dialog box in a new separate window. Select the file and then hit open. It will upload the file. Here is where the system can trick you. Often the dialog box doesn't include the UPLOAD button. It can be and often is hidden and the dialog box has to be expanded to see this button. YOU HAVE TO HIT THE UPLOAD BUTTON FOR THE FILE TO BE LOADED. I have included a picture of the dialog box with the upload button shown. This is not always the case. The uploaded file will not show till you hit (SUBMIT REPLY) You will be taken to the forum with your picture now be visible. Sorry for the Long description. Once you get used to it, I can add a picture in less than ten seconds. Cheers. Sorry if this is off topic. This information is also in the FAQ's |
#16 |
If the toggle switch is ignition (run) one side should have 12v and the other side would go to HEI. Would start by tracing those wires from switch and checking for voltage. If no 12v at switch, maybe key has to be inserted and put to accessory or run to power circuit switch is using from fuse box.
#17 |
Steeveedee, No worries about the time estimate. And sorry if I somehow implied that you would ever drink and drive. We all know that you know better. :-)
Accelerate, Thanks for the information on uploading a picture. Do you know if that process works on an iPhone? Richard, thanks for the tip. I’ve tried everything except tracing the wires. Tracing wires through a firewall by oneself can be a bit challenging. None of my cited friends are gearheads. For that matter, neither are my blind friends. At any rate, thanks for all the tips. Thanks, DNBG Posted via Mobile Device |
#18 | |
![]() ![]() ![]() Join Date: Jan 2018
Also, if you want to add more than one picture to your post, you must select one picture then hit the upload button for each picture you want in your post. You can use the preview post button to see how the post will look before you post it
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#19 |
The Older Generation
1. HEI BAT location. 2. Resistance wire location. If you are ambitious you can remove this wire and run a new 12ga wire from here to the BAT terminal on HEI. 3. IGN Unfused connection on fuse panel. If you are not ambitious you can run a 12ga wire from this terminal to the BAT terminal on the HEI Both work with the ignition switch.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-03-2022 at 11:35 AM. |
| Bookmarks |
