Old 02-20-2022, 10:33 PM   #1
hooverfish
hooverfish's Avatar
Rough idle on cold start ?
My 84 has orig stock 6 cylinder automatic, electric choke, fresh rebuilt 2 barrel carb. Engine is orig with 90k, still has smog pump. Also recent tune-up.
After it sits all night it runs terrible for 1 or two minutes, then smooths out and runs fine, runs fine on warm start.
Would like to get some ideas on what to fix.
If it's the choke, I dont know how to adjust electric choke so help with that would be great.
Or any other ideas on what to try ?
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 02-20-2022, 11:06 PM   #2
geezer#99
geezer#99's Avatar
Re: Rough idle on cold start ?
Could be your choke blade is not open enough on first start and it runs rich and rough.
The choke pull off should pull the blade open about 1/4 inch on start up.
Easy to check.
Just start it up with the air cleaner lid off and gently push on the choke blade opposite of the blades opening
and see how it reacts.
Usually only needs a tiny bit more opening.
What carb you got?
Can you take some pics of it.
Old 02-21-2022, 09:50 AM   #3
hooverfish
hooverfish's Avatar
Here's some pictures.
Started engine with lid off, choke only opens 1/16 to 1/8 inch.
I pulled it open a little farther and idle speed increased seemed to run better.
Carb is a Rochester 2SE
Larry
Old 02-21-2022, 10:14 AM   #4
geezer#99
geezer#99's Avatar
First thing I’d try is adjusting the black cap. It might have a lean/rich indicator on the cap.
Loosen the three screws holding it on and rotate the cap a bit towards the lean side. It might not take much.
If no marking on the cap then just hold the throttle open slightly and rotate the cap and watch the choke blade. It’ll be easy to see which way to turn it to make it leaner.
You won’t need to make much of an adjustment.
Old 02-21-2022, 05:57 PM   #5
Shugalou
Shugalou's Avatar
Have you tried the bolts that hold the carb down? Mine was running really ruff and it turned out they needed to be tightened down again...hopefully that helps as it is an easy fix
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 02-22-2022, 05:37 PM   #6
hooverfish
hooverfish's Avatar
I loosened the screws and turned the black cap about 3/16" to the right.
Let it sit overnight, started and it RAN MUCH BETTER, smooth fast idle.
I'm going to drive it like this for a week or two before anymore adjustments.
Think this has pretty much fixed my problem. Thank you very much !!
I installed this carb last summer, then re-tightened the bolts in the fall. Thank you for your input, it's what makes this a great forum.
Larry
Old 03-04-2022, 01:32 PM   #7
geezer#99
geezer#99's Avatar
Did the choke adjustment continue to help?
Old 03-04-2022, 06:31 PM   #8
hooverfish
hooverfish's Avatar
Absolutely. I've moved it just a little more and it's perfect. So much better.
High speed idle before kick-down is nice and smooth.
Thanks again for your help.
Larry
Old 03-04-2022, 07:07 PM   #9
geezer#99
geezer#99's Avatar
You’ve made my day!
Keep on truckin’.
