Old 02-18-2022, 01:48 PM   #1
69BB396
69BB396's Avatar
Chrome going back on
Chevy is in the paint shop, and adding all new chrome.
With new doors, box sides etc. no chrome mounting holes.
My body guy is ultra fussy on where everything goes.
I do know where the emblems go.
Anyone can point us in the right direction greatly appreciated!
69 396BB Turbo 400 Fleetside, 3:07 Gears
2.5" & 4" drop
2020 Silverado 2500LT
2006 Subaru Forester
2019 Chevy Cruze
69BB396 is offline   Reply With Quote
Old 02-18-2022, 06:44 PM   #2
HO455
HO455's Avatar
Re: Chrome going back on
What year model and appearance package are you planning to have installed?
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 02-18-2022, 08:40 PM   #3
notsolo
notsolo's Avatar
Are you looking for factory trim instructions...like this.....measurements are in 10/th's of an inch, makes it a real head scratcher.
notsolo is offline   Reply With Quote
Old 03-03-2022, 08:50 PM   #4
69BB396
69BB396's Avatar
Mine is a 1969 C10.
Upper and lower complete both sides.
Tailgate too.
Have a peek at my photo on the left, its original.
2.5" & 4" drop
2019 Chevy Cruze
Old 03-03-2022, 08:50 PM   #5
69BB396
69BB396's Avatar
Sure that would be great!
2.5" & 4" drop
2019 Chevy Cruze
Old 03-04-2022, 04:23 PM   #6
Accelo
Accelo's Avatar
The issue with the factory location diagrams is the reference lines are not defined.
Check out the Horizontal reference line (15) what is the location? The chrome side molding or a sheet metal crease?
The front to back holes are located by using (line 115) Again no reference.
Ends up you know the distance between the holes it about it.
You are better off to locate the top of the side molding with the tail light and use that.
Be sure your bed is lined up with the cab and run a tape line all the way front to back.
I had the same issue with the tail light bezel. I got it but it took awhile. I taped around the perimeter of the bezel and then used a felt pen to mark out the position of the bezel.
Then marked the holes on the tape.
Touch up the drilled holes with some paint before installing the clips. Try the clips in the holes before mounting them on the trim to be sure they fit in the holes, quality control it terrible and varies by manufacture. Sometimes greasing the clips before installing is required.
Cheers.
Accelo is offline   Reply With Quote
Old 03-04-2022, 05:03 PM   #7
69BB396
69BB396's Avatar
Be sure your bed is lined up with the cab and run a tap line all the way front to back.
Cheers.
Super thanks.
Gonna test fit everything before paint.
2.5" & 4" drop
2019 Chevy Cruze
Old 03-05-2022, 04:15 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
10/th's was / is old shool manufacturing standard. There is 10 /10th in a inch. So, 5/10ths is a 1/2 inch, etc. you can purchase machinist rulers/scales marked as 10th of measurements. Have fun!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
