Old 03-07-2022, 12:09 AM   #7
bennylava
bennylava's Avatar
Re: If you were building a restomod which modern improvements would you add?
Originally Posted by Corts60 View Post
-better door seals
How would this be accomplished? Maybe somehow there's a way to get bigger thicker door seals. Like you'd see on some BMW's.
Thanks I'm getting a lot of good ideas here! Some of the suggestions I'd already intended to do, but there's some I hadn't thought of. So far from this thread I'll be adding:
1. Auto headlights
2. Bigger better ABS brakes
3. Center console with wireless charging built in
4. Heated seats
5. Some better storage system behind seats and maybe underneath
6. 5 or 6 speed overdrive transmission
7. Limited slip... didn't some of these trucks already have that? Mine is 1987 if that helps
I'm making a big list for when I begin building the truck. If you add these things it makes old classics much more pleasant to drive.
bennylava is offline   Reply With Quote
