Old 03-11-2022, 12:50 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re-Positioning of Fleetside Truck Bed
My '72 C-10 Longbed Fleetside recently got hit in the left rear, behind the rear wheel (driver went thru red light). Besides the obvious damage, I noticed that the front of the bed is now not lined up with the cab. It is about 1/2 Inch over more that it should be. My question is, if I loosen all the bolts would there be enough play to move it back over before I re-tighten them again?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 03-11-2022, 01:01 PM   #2
RustyPile
RustyPile's Avatar
Re: Re-Positioning of Fleetside Truck Bed
The misaligned bed is the least of your worries. The frame is probably bent.. The other driver's insurance should take care of any damage to your vehicle.
RustyPile is offline   Reply With Quote
Old 03-11-2022, 01:34 PM   #3
C10 - C90 Bill
Although possible, I doubt I have any frame problems, although we will find out in time. I believe the bed just got jolted over a bit. And yes, her insurance will cover all the damages and so far so good, they are being very co-operative.
GMC 9500 Fan
Detroit Diesel Fan
Old 03-11-2022, 01:37 PM   #4
RustyPile
RustyPile's Avatar
What does the body shop say??
Old 03-11-2022, 01:51 PM   #5
C10 - C90 Bill
He hasn't seen it yet, but will be soon. He will be doing some of the work, I'll be doing the rest myself.
GMC 9500 Fan
Detroit Diesel Fan
Old 03-11-2022, 01:55 PM   #6
sick472
sick472's Avatar
Loosening the bed bolts and trying to shift it is definitely worth a try. I would make sure that it does not compromise the insurance pay out before I did, however.
I doubt that a truck bed has a full inch of slop, meaning...a half inch to the left of center plus a half inch to the right of center, but depending on where your bed is compared to the overall slop, you could get it to move the 1/2" you need.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-11-2022, 03:14 PM   #7
C10 - C90 Bill
I'm just planning ahead after the insurance pay out as well as writing out a claim sheet on what needs to be done. Actually a 1/2 Inch over total is all I would need. The left side is about 1/2 Inch too far out, where the right side is about 1/2 Inch too far in. It may even be just 3/8's.
GMC 9500 Fan
Detroit Diesel Fan
Old 03-11-2022, 03:47 PM   #8
Grumpy old man
Grumpy old man's Avatar
Don't take it back from the body shop before it's been checked on a frame machine , DON'T settle with them until it's fixed , Insurance companies are always quick to offer a check when they know it's gonna cost them a lot more than they are offering . Just straightening the bed won't make it drive down the road straight and if it's bent you'll be buying tires faster than your last girlfriend dumped you !
Old 03-11-2022, 08:23 PM   #9
TALLone71
a lot of good advice in this post,can you post us some pictures to see how bad the damage is overall.i agree to make sure everything is ok with a shop of your choice, another thought is how rusty the bed mounting bolts may be where they pass through the cross sills, I have seen them where they looked ok on the top side and where all but corroded away where they pass through the lower side.that may have allowed them to give and let the bed shift slightly to one side, just something else to check. either which way make sure its good in every way, before you settle, its amazing how far collision damage can reach into a vehicle and be hidden from the eye
:chevy
TALLone71 is offline   Reply With Quote
Old 03-11-2022, 10:53 PM   #10
C10 - C90 Bill
Appreciate all the replies.
GMC 9500 Fan
Detroit Diesel Fan
Old 03-12-2022, 12:41 AM   #11
rickcdewitt
rickcdewitt's Avatar
If the bed actually shifted on the frame you'll be able to crawl underneath and see marks on the bed ribs where it used to sit
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 03-12-2022, 01:11 AM   #12
MySons68C20
MySons68C20's Avatar
Best advice....look for witness marks. It may be that simple.
MySons68C20 is offline   Reply With Quote
