Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-12-2022, 08:27 AM   #27
RoyL
RoyL's Avatar
Re: Burb Gas Tank for EFI Conversion?
Originally Posted by lownslw64 View Post
The boyd tank is 19 gallons, My fill is 10.75 to center of pipe from front of tank and I left how it was placed from side to side in their standard location. It would be to your benefit to move that in a inch or two so when you install you can put it straight up and not have to angle into position. The pipe size is 1.5" also. The only issue i had with this setup is i also bought the rollover vent i think it's called but due to the location of the fill it would keep it closed when filling and not allow the tank to breathe causing it to always shut off. i ended up taking it out.
Originally Posted by RoyL View Post
Thx for the info! Can you please clarify what you mean by the above in blue? Confused as to where the "standard location" is?
Can you clarify what you mean by "My fill is 10.75 to center of pipe from front of tank and I left how it was placed from side to side in their standard location. It would be to your benefit to move that in a inch or two so when you install you can put it straight up and not have to angle into position." Do you mean move it in 1 or 2 inches less than the 10.75"? Or you would move their "standard" location? Not sure what the standard location is...?
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
