Old 03-13-2022, 02:14 PM   #1
Jbrem010
1968 C10 disc brake conversion- MC question
Hey all,
I'm looking to convert my '68 C10 to front disc brakes. I understand I'll need to change the prop valve; do I need to replace the MC in this pic? Sorry if I haven't given you enough info. The front chamber of the MC is larger and the line fittings measure 7/16" and 9/16".
Jbrem010 is offline   Reply With Quote
Old 03-13-2022, 05:09 PM   #2
68Gold/white
Re: 1968 C10 disc brake conversion- MC question
Man, I don't know exactley what you've got there for a booster, m/cyl snd prop valve. It all looks like disc brake stuff to me looks like a setup from a 73-up Chevrolet pickup.
All the GM m/cyls I've seen with a larger fluid compartment were for front disc/rear drum.
Of course I have not seen them all, but I worked in a parts store for 13 years, from 1985-1998. Some all drum fords had a larger compartment on one end of some of their m/cyls, your m/cyl is NOT a ford...
68Gold/white is offline   Reply With Quote
Old 03-13-2022, 05:49 PM   #3
Jbrem010
Okay, thank you 68G/W. Is there a specific PV you would recommend assuming the MC is correct? I currently have drum/drum brakes now. Thanks again for your input.
Old 03-13-2022, 06:02 PM   #4
MikeB
MikeB's Avatar
Yes, very strange setup. I'd use a manual prop valve in the rear line and adjust to maximum pressure. Then reduce pressure as necessary if the rears lock up before the fronts during a panic stop.
Wilwood 260-12627
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-14-2022, 12:45 PM   #5
Jbrem010
Okay guys, what's odd about the setup? I don't know as much as you all do. Would the Wilwood adjustable PV go in place of the current PV? What about the front brakes? Sorry for all of the questions.
Old 03-14-2022, 01:05 PM   #6
68Gold/white
You might look for a part number on the Prop valve?
THe all drum and disc prop valves look nearly the same. I'm sure you can find a disc/drum prop valve here, used....to be safe. New may not be that much.
If you could get a look at a 73-up prop valve, that might be nice...
Old 03-14-2022, 01:54 PM   #7
geezer#99
geezer#99's Avatar
The wilwood adjustable is spliced into the rear line. Leave the rest as it is.
Somebody is gonna come along and say that’s not right but I’ve done it like that several times. Not all prop valves are the same. You’d need to find one that’s sized right for your system.
Old 03-14-2022, 02:14 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's right. Keith Seymour posted some charts for the various equipment for brakes. If the OP's truck doesn't have disc brakes, he should buy a disc brake master cylinder. imo. No telling what the current master is, and if it's currently a drum/drum system can't possibly be plumbed right for disc/drum. I ended up putting the Wilwood valve on my truck, like MikeB posted. The brakes work great.
~Steven
Simi Valley, CA
Old 03-14-2022, 02:23 PM   #9
MikeB
MikeB's Avatar
Steeveedee -- Well said.
Mike
Old 03-14-2022, 09:58 PM   #10
Jbrem010
Okay, thanks guys. I think I'll pick up a disc/drum prop valve. You've confirmed the MC should work. Thanks again.
Old 03-15-2022, 11:02 AM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
You have what appears to be a 3/4 ton master cylinder and booster. The valve below the master is not a proportioning valve, but a distribution valve that will not work with disc brakes. You will need to get a master cylinder, booster, and prop valve for a 71-72 half ton and you can either use the original hard lines or buy new lines and you will need new hoses for the calipers, along with the spindles. Member Pickmup (Frank) sells a complete master/booster/prop valve kit for 1/2 tons.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-11-2022, 08:43 AM   #12
Jbrem010
Hey everyone, I grabbed a set of 2.5" drop spindles and the disc brake conversion kit from CPP. The previous owner heated the front springs and they are uneven so I'm replacing them with 2" drop springs. The brake hose that came with the conversion kit has a 7/16" inverted flare fitting and the OEM brake is a 3/8" inverted flare. The adapter is BR550 (reminds me of Hee-Haw if anyone gets that one. :-) I read the brake hose 88466 would be what would be needed since it is shorter and I found it has a 3/8" inverted flare fitting. Awesome, no adapter!! Got them installed last night after paying around $13 ea at Autozone. 88466 is 4" shorter than the hose that came with the kit and I had to file out the hose frame hole to fit and secure the fitting. I hope it is long enough, an inch or two longer would have made it just right.
Old 04-11-2022, 09:08 AM   #13
72c20customcamper
72c20customcamper's Avatar
Originally Posted by Jbrem010 View Post
Hey all,
That unit looks like a Buick olds setup.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 04-11-2022, 09:21 AM   #14
Grumpy old man
Grumpy old man's Avatar
This thread has some good info . You want to watch for chaffing .
https://67-72chevytrucks.com/vboard/...d.php?t=818077
Old 04-23-2022, 08:41 PM   #15
Jbrem010
Hey guys, I've moved on to installation of a Summit Racing adjustable proportioning valve and I'm building lines from it to the MC. I have everything figured out except the 1/4" OEM rear brake line is a 1/2-20 fitting and I need to reduce this to 3/8-24 to fit the prop valve. Has anyone came across a 1/2-20 inverted flare female to 3/8-24 inverted flare male fitting? I've been scouring the Internet with no success.
Old 04-23-2022, 10:34 PM   #16
jocko
jocko's Avatar
Actually, I think people have confirmed you still need a correct disk/drum MC. Note that all your lines in post #1 are 1/4". Stock disk/drum lines are 3/16" (to front disks) and 1/4" to rear drum. Will it work if you just install a prop valve and do nothing else? Perhaps. Will it work correctly? Not likely - or at least not like a stock disk/drum system was engineered to work. Recommend not skimp on the parts or go crazy with mixing and matching systems - a new correct MC is not very expensive and GM engineered the original brake systems to the truck (71-72 C10 brake systems is the model you'd want to emulate).
