Old 07-26-2004, 08:23 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
New Progress Pics of 71
Well I finally figured out how to shrink the size of my digital photos small enough to post them. Not sure if any of you remember, but I bought a 71 Blazer (blue with black stripe down hood) off ebay back in april. It needed complete restoration. I had to remove the front clip, take the engine/tranny out (350/465), installed new wiring harness, rockers, intake, headers, alternator, seats, carpet, clutch, carburater, weatherstripping, etc...
I've taken pictures all along but realized a setting on the camera was set at the highest resolution, making them way too big to post. I've fixed that problem for new photos but have yet to figure out how to shrink the existing ones from the earlier work in order to post them. Anyway, attached are some pics of the primed floor before the carpet install. I had to fabricate a good chunk of the floor (where it meets the rockers). I'm not expert welder, but it came out alright. I'm using seats from a 90 K5 that I used to have that was totalled when I let someone else drive it (ex-girlfriend). I had to weld in some homemade brackets to allow the frames to bolt into the floor. I'll post more pictures as I go, lots more to do, but I am over the hump!
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 07-27-2004, 12:32 PM   #2
Yukon Jack
Yukon Jack's Avatar
Definitely keep us up to date on your project.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-23-2004, 02:15 PM   #3
mokie
Mokie
Looking good. How much is a welder? I've seen others on this site say gas is the way to go. Was it hard doing the welding on your rig because it looks awesome. As Yukon Jack says, "Definitely keep us up to date..."
mokie is offline   Reply With Quote
Old 08-24-2004, 06:45 AM   #4
Madbomber88
Active Member
The welder I have is a Miller Mig, I forget the exact model, but I picked it up at Grainger a year or so ago for around $700. It sure does make a difference, and using gas makes it even better. Don't bother welding with the flux core wire that doesn't require gas, it's messy and not worth it.
71 Blazer CST
72 K20
Capt USAF
