Old 07-19-2004, 11:55 PM   #1
gman
Stock arrangement of emission hoses
Does anyone have a layout with pictures of the proper routing and location
of the emission hoses on a '72 with a 350 motor and quadrajet? I'm
referring to the hoses coming from and going to the charcoal
canister........I know the vent line from the gas tank goes to the "gas"
connection on the canister. But I'm uncertain of the exact routing of the
other two. I know they attach to the carb but not sure how. Can't find
specifics in the service manual. Any help would be greatly appreciated.
Thanks.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 07-20-2004, 12:32 AM   #2
cdowns
cdowns's Avatar
the assembly manual has those pictures maybe somebody can scan them for you
Old 07-20-2004, 02:35 AM   #3
71-longbed
Its Magically Delicious
71-longbed's Avatar
i wouldnt mind that either .. just to make sure mine are running right
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 07-20-2004, 12:03 PM   #4
Harold Shepard
The hose that comes from the canister to the carb 1/4 line gets a tee fitting and ties into the pvc system at the front of the carb. The smaller vaccum line attaches at the higher ported vac. port on the carb. On the 4mv carb the vac. advance should attach at the port on the lower right and the canister should attach at upper left port on the carb.
Harold Shepard is offline   Reply With Quote
Old 07-22-2004, 02:15 PM   #5
gman
I've got a factory assembly manual and I can't find a pic of it in there anywhere.
Harold..........I do have the 4MV q-jet. Just so I understand then......the 1/4 inch line goes into a "T" fitting that will also have the line from the PVC line going into the "T", which will then go into the unported vacuum at the bottom of the carb. The smaller 3/16 inch line goes where? I have the original air cleaner and I thought one of those lines from the canister attached to the air cleaner? Anybody else?
Old 07-22-2004, 02:30 PM   #6
71-longbed
71-longbed's Avatar
the air cleaner hooks to the passenger side port on the carb... mine is capped in the pic... i believe the rest of the hoses are stock ... hope this helps let me know if anyone has it diferently .. notice the tee on the pcv hose
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 07-22-2004, 08:36 PM   #7
Harold Shepard
If you look at 71 longbed's pic, the capped port is for the door located in the stock air cleaner, as he said. The tee is correct, mine is located closer to the port, personal preference looks a little cleaner, the 3/16 hose FROM the canister should attach to the port just above the fuel inlet fitting, not tho be confused with the one for the choke pull-off almost directly behind the fitting and the vaccumn advanve should hook to the port on the driver's side next to the fast idle solenoid. Hope that helps you out.
Old 07-22-2004, 10:20 PM   #8
gman
Thank you very much.
Old 07-23-2004, 01:28 AM   #9
71-longbed
71-longbed's Avatar
my vacuum advance comes from the a port on the fast idle solenoid ... i know it works *becuase i've always had it that way".... does anyone know if there are any advantages or disadvantages to tweaking with the stock setup ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 07-26-2004, 11:07 PM   #10
CaperCat
CaperCat's Avatar
Thanks for the emission hose lesson. I just need one more thing; There are two vacuum ports on the A/C solenoid. What connects to those ports and all should be well. I too have a '71 350 with A/C. Thanks.
Steve
CaperCat is offline   Reply With Quote
Old 07-27-2004, 04:13 AM   #11
71-longbed
71-longbed's Avatar
ok .. is it a ac solenoid or a fast idle ....fast idle cams on the passenger side ...
i'fe heard that solenoid called many diferent things .... according to gm its a idle control solenoid... but some tell me its AC related ... which is it ...
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 07-27-2004, 09:09 AM   #12
CaperCat
CaperCat's Avatar
That solendoid only kick in when the A/C is turned on. That's why you do not adjust the fast idle speed with this solenoid. It is an idle control solenoid used when the A/C is turned on. It compensates for the extra load on the engine to run the A/C compressor.
We have the same truck, except mine is light red and white and stock.
Old 07-27-2004, 11:25 AM   #13
71-longbed
71-longbed's Avatar
ok ..now my question is .. my truck doesn't have AC ... can i bypass the solenoid some how ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 07-27-2004, 01:42 PM   #14
Harold Shepard
Capercat, Which side of the intake is the solenoid you are talking about on? The solenoid on the carb is a fast idle solenoid, but it should only have an electical connection on it. If the solenoid is on the passenger side, it may be the TCS solenoid. If this is the case it connects by a flat conector to the transmission and attaches to the distributer's vacumn line- I think the nipple that points up is the in - and the nipple that points to the front goes to the vacumn port on the carb. 71 longbed the solenoid is a fast idle solenoid and you can unhook it, it was put in place to the prevent run on and spark knock after the engine was shut down as well as a load compensator when things lie a/c were in place to prevent the idle speed from falling too low- has something to do with the lean drop issue in the carb- GM was detuning everything to meet new emission standards that started in 71 and carried forward.
