C30 Disc brake spindles
I'm replacing everything brake related on my 69 C30, and I figured I might as well upgrade to front disc brakes. Thing is, I've done some searching and many threads I've gone through come down to "just go buy a donor truck" which doesn't give me any answers. I cannot find a 1 ton donor around me. I've looked and the only 1 ton I can even find for sale is $9,000 as a running driving ramp truck. Even if I did find one, I would still want to be buying new rotors, pads, and calipers instead of reusing old used ones. So I would be buying a whole truck for just a couple parts.
I'm trying to find out if I need control arms and spindles, or will the disc spindles bolt to my control arms. I'm also searching for a set of spindles. With the difference I've seen between C20 and C30 rotors, is there a difference between C20 and C30 spindles? I've been looking for a set of factory spindles for a C30 and cannot find any at all, new or used. I used to work at a parts house and talked to "the guy" who can find almost anything and he still came up blank. I've looked at all the big parts houses, looked online including just general google searches and cannot find any period. My best source is driving around to junk yards to see if they've got a donor truck I can pull them off of. Even at that, yards are few and far between for me. Posted via Mobile Device |
The Older Generation
Re: C30 Disc brake spindles
I can't say for sure on the '69. I just put '73, complete C30 spindle/rotor/caliper assemblies on a '72 GMC C20 frame and it was a bolt on deal. but it had disks to start with..... I know the answer is on here somewhere but I'm just not sure where. If you figure out the '69 C20 to '72 C20 conversion then the '73 C30 stuff should bolt on the same way. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-17-2022 at 08:43 PM. |
#3 | |
Miffed that. Was trying to quote and screwed it all up.
Thanks for the link I hadn't seen that yet. So between you and the link, it looks like my missing link is the spindle. I have found a few factory height C20 spindles, but none of them have also been listed for a C30 which makes me think there is a difference between them. I know the dually wheels necessitate a change in the rotor design from the C20 to the C30, but that also has me questioning whether the spindles are different as well. Posted via Mobile Device |
#5 | |
I just unbolted the upper and lower ball joints & tie rods on the '72 C20 spindles, removed the spindles, set the '73 C30 spindles in place and bolted the '72 C20 ball joints and tie rods into place in the C30 spindles. You can see it in my Dually build/project thread link in my signature below. Like you, I know the rotors are different but not sure about the spindles themselves. I never disassembled either one. LockDoc -
My desktop was on mobile view for some reason. Was wondering why I couldn't see anyone's sigs.
Thanks for all your help LockDoc. Now I need to do some digging and see if I can find out if there's a difference between the C20 and C30 spindles. At least I know they should bolt up either way. |
For anyone looking in the future, it seems the C20 and C30 spindles are indeed the same part. The difference comes in with the rotors.
http://67-72chevytrucks.com/vboard/s...d.php?t=741216 |
![]() Join Date: Dec 2009
Thanks for posting this
![]() I will put Disc on the front of my 67 C30. I got the (Set-up) spindles and rotors and calipers, from a Pick your part a few years ago. I got them For the spindles and will use rotors and calipers for cores. They came from a Square body. Do you plan to do a Thread on your swap?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#9 | |
Thanks for that. For some reason I didn't come across that thread when I did my research a year or so ago. LockDoc -
#10 | |
I wish I had a decent junk yard around me. I transplanted from roughly St. Louis to middle of nowhere Tennessee about 4 years ago. The closest decent yard is about an hour and a half away in Nashville. There are others, but they've all got just a handfull of cars and nothing I'm interested in for this whole project. I may do a build thread. I actually hadn't thought about it until you said something. Along with the brakes, I'm replacing all of the suspension and steering parts. My truck has a freshly rebuilt gen 5 big block and a well used SM465. The truck was never maintained well so I'm just going through and making it mechanically new, so I can actually use it. I'm also replacing the transmission with a T56 thats sitting in another truck which is half built and unusable. Between the old transmission and my 4.10 rear end I'm doing good to cruise at 55 and the mileage ends up being really poor. I know I know, big block and mileage don't go together. With the overdrive I can get my rpms down and hopefully get out of single digit territory. Also ditching the in cab fuel tank for an under bed deal. |
I was thinking of a 5 speed swap.
A T56 would be Great. Hope you decide on the build thread
![]() Join Date: Apr 2008
You should do a build thread, not enough C30 builds here.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
Will T56's hold up in a C30?
Either way, thank you for posting that C20-30 spindles are the same, good to know. |
Its a Truck Thing......
Well,
In that thread that was posted I can get the part numbers off 73+ up C30 spindles if needed. I have a few sets of spindles and a full Front Crossmember for one of my One Tons. Smitty
71 C10 283/3SPD Full Resto 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#15 | |
I believe Tony was a member here a while back & has been active on Instagram lately w/several guys coming from out of state to get C30 parts from his place. He has lots of truck & suburban donors so it's possible he has what you need. If you need help getting something shipped from him, I know another local guy to me that's doing in state (TX) delivery runs but occasionally does trips elsewhere for customers (hotrod_haven on Instagram). It's possible you could arrange meeting somewhere that helps you/works for him. BOTH of these guys are stand-up die hard gearheads so I don't hesitate to suggest them.
#16 | |
The encouraging things I know are, I have seen a few threads where guys were towing other vehicles with their T56 swapped C1500's. And the SRT10 Ram came with them. Where I used to live there were several guys who bought them just so they can tow their viper to the track with their viper truck. |
#17 |
Best I've found is classic industries has a set for $250. I may get ahold of you once I get to that point. Rear end is out right now, transmission and half the interior is next.
#18 | |
#19 | |
Figured it could be a possibility to keep in mind if you can't source what you need around your home area.
| Bookmarks |
