![]() Join Date: Jan 2009
WTB 2 bbl carburetor
I need a good ready to install 2 barrel carburetor for my 6 cylinder GMC.
Pulatoy Last edited by paul mora; 03-19-2022 at 03:35 PM. |
Re: WTB 2 bbl carburetor
I think you need to narrow it down!
Are you looking for a Rochester 2g, stromberg, varajet, dual jet or something else. Which 6 cylinder helps too. |
Rochester
Pulatoy |
That’s a 1 barrel mono jet.
Do you have an adaptor or other intake. |
What you see is on the truck and is not working Then rebuilder is 6 weeks behind and I thought I would check here to see if anyone has one they do not need. Next option is tho go to Classic Industries and see if they one on the shelf
Pulatoy |
Try carb shop. Ontario California
Rebuilding a Monojet is pretty simple and is probably less work than an adapter and headaches of the conversion. Rebuilding a 2-jet is pretty much the same.
A can of B12 and a carb kit isn't expensive. |
| Bookmarks |
