Old 03-22-2022, 01:53 PM   #1
GMC71k20
C4 Corvette accessories
I'm installing an LT1 with Corvette accessories into a 67 c10 and was hoping someone has experience with this.
I could use advice in how to mount a power steering reservoir for the power steering
GMC71k20 is offline   Reply With Quote
Old 03-22-2022, 02:02 PM   #2
Accelo
Accelo's Avatar
Re: C4 Corvette accessories
Could you use a BB remote reservoir and mount it on the fender like stock?
Accelo is offline   Reply With Quote
Old 03-22-2022, 04:18 PM   #3
MARKDTN
I did a C4 Tuned Port in '72 for a guy and that is what I did.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-22-2022, 06:23 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
There are a few different pictures of the big block reservoirs in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=735249
LockDoc
Leon
Old 03-22-2022, 08:13 PM   #5
GMC71k20
Thanks everyone, that's a big help.
I will be emulating the factory bracket and reservoir, that's the ideal spot but I was hesitant since I never noticed BB trucks had them
Old 03-22-2022, 10:11 PM   #6
LockDoc
LockDoc's Avatar
I think I have an extra fender mount setup. If you are interested I will check in the morning and post it on the parts board.
LockDoc
Leon
Old 03-23-2022, 07:37 AM   #7
GMC71k20
LockDoc
I appreciate the offer but I already have a nice aftermarket Corvette reservoir.
I do have a question about the pump return line though. What kind of path did your return to the pump take? The return nozzle on the pump points toward the passenger side and the hose will have to do a 180* turn if I mount the reservoir on the driver side. I could get a cleaner angle if I mount the reservoir on the passenger side but then the other hoses get longer
I can post pictures later today to clarify
Old 03-23-2022, 09:10 AM   #8
LockDoc
LockDoc's Avatar
Unfortunately I have never had a stock big block truck that had an engine in it so I can't answer your question. Hopefully someone else will chime in that has.
LockDoc
Leon
Old 03-24-2022, 12:36 PM   #9
MARKDTN
Interesting. A TPI Corvette has the reservoir drivers side and high. An LT1 Corvette has it passenger side. I did not realize that. Since you are using the C4 accessories, why not use a C4 reservoir in the stock location? I would not want a 180 in that line as it just invites cavitation so for me it would have to go on the passenger side to keep the suction hose as straight as possible. For that longer lines is more volume and should run cooler. On the one I did, I went to a hydraulic shop and bought a piece of hydraulic suction hose to connect the pump and reservoir.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 03-24-2022, 01:13 PM   #10
GMC71k20
I agree with all of this and appreciate the help. I'll be mounting along the passenger side now. I'll be asking for suction hose when I make the trip over to the hydraulic shop as well
