![]() Join Date: Feb 2009
72 transfer case skid plate
I’ve got a 72 CST Blazer with an automatic and no skid plate, and a 72 K5 with a four speed and it has the tranny/transfer case skid plat. I’m wondering did they put skid plates with an automatic? It looks like the extra crossmember would hit the automatic shift linkage? Hope this makes sense
All about them K’s
![]() Join Date: Jun 2014
Re: 72 transfer case skid plate
I don’t have an answer here other than to say the 465/205 combo makes a great skid plate on its own
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Dec 1999
Doesn't the extra crossmember go behind the t-case? Not sure how that would interfere with the trans linkage. Linkage terminates toward middle/front of trans. Most of the additional crossmembers I have seen supporting the skid do not utilize the sections that tie crossmember into upper frame as well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#4 | |
I have a ‘72 4 speed Jimmy without skidplates and a ‘72 automatic Jimmy that has skidplates. It does have the second crossmember and it is on the SPID.
As your skid is original I am curious if the second crossmember has the braces going to upper frame rail.
It is and it’s on the SPID. Only the front crossmember has the braces going to the top of the frame. We did a frame swap on the automatic truck and both the original and replacement frames had skid plate equipment and neither had braces to the frame on the rear crossmember.
#8 | |
