Old 03-23-2022, 02:13 PM   #1
Puglia10
454/dana 70...highway gears?
I have a 1979 GMC crew cab dually. 454, th400, and a dana70HD rear end.
I still need to figure out what gears I have in there, but I assume 4.10 or 4.56 because the motor is screaming at 60mph.
I'd like it to be more highway friendly (70 all day, 75 would be nice) I'm not terribly concerned with gas mileage because it's a toy, and will only be towing a couple Harleys, or one hot rod...nothing crazy heavy, and even that will be rare. Mostly just building a fun cruiser that I can take to some shows...and again, maybe bring a couple bikes. Pulling a car MIGHT be once a year.
I know gear vendors or 4l80e would probably make the most sense, but for a quick and inexpensive fix, I am wondering what gear ratio would make sense for the highway driving, but still be able to move the big truck (with 22" Alcoas and adapters) and go up a hill.
At what point is the gearing too high that it won't be able to move around town?
Thanks!
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 03-23-2022, 04:14 PM   #2
Big Chip
Big Chip's Avatar
Re: 454/dana 70...highway gears?
I have the same engine and trans and I can tell you 3.73 isn't much better than what you're describing. It's not too bad at 70 but the truck was clearly designed for the 55mph speed limit.
Big Chip is offline   Reply With Quote
Old 03-23-2022, 05:02 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
3.42’s would probably be your best to bring the rpm’s down yet still be able to tow decent.
Old 03-23-2022, 10:13 PM   #4
kwmech
Tire size is also a factor. Some of the trucks came with 215/75r-16s. A good upgrade is going to a 235/85r-16. I think I have a pretty good combo in my dually with 235s, 4.10s and a Gear Vendor which has a 22% overdrive
Old 03-24-2022, 12:15 PM   #5
MARKDTN
4L80E is a .75 overdrive so even with a 4.56 gear it makes it a 3.42 in overdrive (4.11 is 3.08 in OD). That seems like to way to go to me. There are aftermarket stand alone controllers for them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-24-2022, 03:06 PM   #6
66gmcguy
In my opinion, the only way to get a more useable highway gear is to add some type of overdrive. I went from 3.73s to 3.08s in my chevelle to be in a more highway-friendly RPM range, and it didn't make that much of a difference on the highway, but it made it way more sluggish in 1st and 2nd. I hated it, and was out a bunch of time and money that could have otherwise gone to putting in an overdrive transmission. I would look into a 4L80E, or if you're like me and don't like automatics, get an NV4500.
66gmcguy is offline   Reply With Quote
Old 03-24-2022, 04:45 PM   #7
Dead Parrot
My 75 C10 with a mostly stock 350/TH350 and 3.42 rear gears + LT 235/75 15 inch tires (approx 28" diameter) does fine at 70~75 mph on long trips. Can get 3400lbs of trailer and gravel moving as well but doesn't set any 0-60 records during the process.
Play with some of the online RPM calculators before deciding anything.
Dead Parrot is offline   Reply With Quote
Old 05-03-2022, 11:40 AM   #8
Puglia10
just to put some closure in this thread, I ended up ordering a gear vendors overdrive. Not cheap, but the reviews are great and after pricing out a rebuilt 4l80e and controller, plus the extra amount of work, it wasn't a big difference. I'll try to remember to report back after I drive it. It makes my 4:10s act like 3.20 on the highway.
1979 c30 3+3 dually
1946 GMC
Old 05-03-2022, 10:44 PM   #9
chris989
If possible,, reconsider the 4L80... the gear vendor is nice but it does not lock up the converter.
Having the converter lock is almost like getting another gear. I swapped a 4l80 behind my 5.7 with 4.56 gears. I run a MSD atomic controller.
It is an easy swap,,check you pick a part,,, pic one up for a few hundred with everything.
Good luck
chris989 is offline   Reply With Quote
Old 05-04-2022, 10:39 AM   #10
SunSoaked
SunSoaked's Avatar
Good luck
Too late! He already bought the GV. I was in this situation and researched my options to death. Finally, I just swapped in a NV4500 and all was good with the universe! Best of everything. With my Edelbrock pro-flo 4, I'm getting around 14-15mpg in my 85 K20.
SunSoaked is offline   Reply With Quote
Old 05-05-2022, 05:11 PM   #11
SCOTI
SCOTI's Avatar
Good luck
4i80e's in my area from a yard are usually in the $6-800 range.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-05-2022, 09:31 PM   #12
chris989
I was grabbing some fenders the other day and there is a 90k mile 2003 2500hd, someone already got the 6.0. but the 4l80 and 14 bolt 411 with disk brakes is just hanging there.
They are only 230$ here
Old 05-05-2022, 10:42 PM   #13
SCOTI
SCOTI's Avatar
Wow. Core price here near DFW is ~$4-500.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-06-2022, 09:14 AM   #14
SCOTI
SCOTI's Avatar
Thanks!
As for gearing changes, I'm not sure how many choices are out there for the HD70 housing. I understood there were limited options w/a 3.54 being the mildest available. 3.54's would still help your situation as far as cruise rpm goes but not by much. Simulations assuming 235/85-16's....
4.56 gear w/a th400 @ 75 = 3625rpm
4.10 gear w/a th400 @ 75 = 3259
3.73 gear w/a th400 @ 75 = 2965
3.54 gear w/a th400 @ 75 = 2814
4.56 gear w/a 4l80e @ 75 = 2719rpm
4.10 gear w/a 4l80e @ 75 = 2444
3.73 gear w/a 4l80e @ 75 = 2223
3.54 gear w/a 4l80e @ 75 = 2111
4.56 gear w/a G.V. @ 75 = 2827rpm
4.10 gear w/a G.V. @ 75 = 2542
3.73 gear w/a G.V. @ 75 = 2313
3.54 gear w/a G.V. @ 75 = 2195
My towing adventures seem to like ~2500rpm to maintain speeds w/the sbc in my CCSWB 3/4 ton & slightly lower rpm's w/the BBC CC dually.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-11-2022, 04:54 PM   #15
factorystock
factorystock's Avatar
IMO, a good move, seems more durable and least amount of modifications. Automatic overdrives have a short shell life if TV cable not adjusted correctly,
factorystock is offline   Reply With Quote
Old 05-11-2022, 05:30 PM   #16
SCOTI
SCOTI's Avatar
4l80e has no TV cable to worry about.
Gear Vendor OD is a great choice as well. Be advised though... On a truck like a CC Squarebody dually, the GV will likely end up about the center of the chassis. Not an issue @ stock height but it definitely becomes one when the truck is dropped 6"F/8"R.
I was considering one but when I looked @ where the bottom of the unit was in relation to the frame it made me nervous (I looked under a 7.4l/TH400/GV equipped Burb for the visual). I decided a 4l80e was a better option w/no worries about clearance since my dually has high centered more than a few times. I didn't want to spend >3k only to whack it in a jacked-up parking lot entrance/exit @ some point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
