Old 03-25-2022, 04:32 AM   #1651
Grizz1963
Grizz1963's Avatar
Re: GRIZZ’s ‘79 - 2WD BLAZER Challenge over in London, England. “~It’s not a Project
Originally Posted by LT7A View Post
I feel that well managed aluminum is a fix for almost anything. And that is a sheet of well-managed aluminum.
Thank you very much.
I am pleased with the outcome.
Friday, and the week from hell ain’t over yet.
More training and bo110x from 9.45 onward, but hey………
Tomorrow’s Saturday.
Got nothing done this week except screwing with screws.
Windscreen screws painted as I could not find 40 new ones to hold down the strips I painted last week.
Removed the clamps and pushed the centre loom through the firewall.
Two more looms to get fitted over the fenders.
Really happy with how tidy it has come out.
Compared to what we started with.
In other news, the puppy is back, still in isolation, but seems fully recovered.
Looking forward to the weekend, still a few hours to go.
Onwards as our friend @pauly says.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 03-25-2022, 10:48 AM   #1652
LT7A
"bo110x"
Hahaha, took me a second.
Old 03-27-2022, 03:24 AM   #1653
Grizz1963
Grizz1963's Avatar
"bo110x"
On a couple of forums the swear filters are fine tuned, so one needs to try be cleverererer……
And often an expletive is just more descriptive.
Good morning after a very short night.
I cooked Nick, John the lodger and myself a lovely chicken curry last night, and in my own case, drank way more than I should have.
Well, a second rum is a rare thing. But usually results in a restless night. But it tasted so good.
Yesterday was one of those MANY JOBS MAKE A DAY kinda days.
Fettling a piece of wood for 2 hours etc.
Started like this.
Sorted some stuff, tidied up stuff and got tools and materials out.
Nick was early, no ringing bells afaik.
By 11.00 I had to run to the village to pick up another brake master cylinder ordered on Friday. £70.00 or about $100.00 at a guess.
Also pharmacy to get some Actifed for Sally who has been sick most of the week and something for me.
Bolted on.
Shiny.
We had hoped the Ford reservoir would fit…..
Looked like a good fit, even initially back to front, but alas…….. the legs are too big to fit in the new holes, which means it needs a different, new reservoir.
Next up, we started to lay the wiring looms for the umpteenth time.
Fuse box and clutch hose mocked up and made up.
Looking encouraging.
Progress.
Looking tidy.
Nick had brought treats for around lunch time.
Short bread cookies.
Time to stand back, discuss, grin, gloat, coffee, plan, enjoy the progress.
Loads of stuff happening in the background, not captured.
More in a bit.
Old 03-27-2022, 03:45 AM   #1654
Grizz1963
Grizz1963's Avatar
Another of those fine tuning, redesigning as you go along jobs.
I had a full sheet of 6mm ply from when I built the teardrop trailer 12 years ago.
And was loathe to cut it up…… Nick insisted that it was what I had saved it for… to be used.
Transferring the layout from the original cheap n nasty ply to the final version took a lot longer than planned.
But we know these jobs take just as long as they should.
It went in and out no less than 10 times to make the basic shape fit, and also for the steering column shroud to fit around and leave room for the vinyl and foam covering.
In Out In Out In Out……..
In Out In…….
Drivers side is slightly lower to cover fuse boxes, pedal boxes and various bits of low hardware.
Next up.
Fitting the instrument cluster.
That took forever.
Eventually happy, very happy.
Switch gear and side panels next.
At some point John the lodger came back home and as always, came to look, advise, help, poke fun.
And took some pics neither @nickwheeler nor I knew he was taking.
No, I have no clue either, but obviously busy with something that consumes time and necessitated being on my knees.
Still not done.
Old 03-27-2022, 04:09 AM   #1655
Grizz1963
Grizz1963's Avatar
Amazing how much time goes into planning.
Thinking how to solve a problem.
What materials to use.
Finding the right materials.
Making a template.
Copying it it onto steel.
Cutting, shaping, drilling, screwing, shaping, grinding, fitting, tack welding, dismantling, full welding, test fitting 6 screws, celebrating.
John the lodgers pics help tell a story.
And mocking up.
Brains go here.
ECU
Keep in mind, the original engine wiring loom needs to come here and be connected to control things.
Welding.
NIIIIIIIIICCCCE !!!
Secure, high and dry.
Ready to be plugged in and tested (much later)
Remember those other little jobs that consume an inordinate amount of time?/
These hinges needed to come off, be cleaned, wire brushed, prepped, painted and refitted later.
Typically one of the countersunk head bolts/screws refused to budge, so drilling out the head with three different drillbits was necessary.
Where does time go?
Two of each of the replacement screws will hold up hooks to support and keep the wiring loom tidy and out the way……
Tempest Fugit.
Last engine bay pic for the day.
Diagnostic plug mounted on the opposite fender , allowing for some symmetry in design.
Loads more to happen today, Sunday.
And lastly……….
A QUESTION TO YOU ALL.
DID WE ACHIEVE ONE OF THE OBJECTIVES?
85mm
Breakfast next.
Old 03-27-2022, 05:52 AM   #1656
Grizz1963
Grizz1963's Avatar
And in other news.
Raffle Tickets available for this new build at US $39.00 per ticket today.
Built in the Philippines to all out Driver Style.
Loving this car.
Old 03-28-2022, 02:14 AM   #1657
Grizz1963
Grizz1963's Avatar
Nipples.
@nickwheeler has been looking forward to to this so much, he even remade them once.
Throttle cable measured, cut, soldered and finished up, fitted and functioning smoothly from the first fit.
All about the planning.
Old vs New.
It also became a day of tying some smaller loose ends, making mini looms, welding in forward earth mounts.
New Side lights/indicators are smaller than the previous ones, so getting them fitted became a wasted hour…….
Plan B will be employed.
Making up retaining clips ultimately failed to deliver a secure mounting for the lights.
On to Plan B.
Next up Nick added the new LED headlights and tested the functions.
Headlight Buckets got to meet Mr Hacksaw.
With the result being rather rewarding.
This in turn resulted in a good outcome that will necessitate removal of the existing radiator mount points, and remaking the retaining top brackets.
Remember them from a few weeks ago??
Now with the headlights bowls reduced in sheer size and depth, allowing the LED lights’ heat sincs to work fully, the radiator and original fan should fot.
More little jobs were done and I did woodwork mostly through the day.
More about that later.
Nick had to head home after 4.00pm for a family gathering, so I carried on till about 18.45 with woodwork and bracketry before shutting shop.
With the clocks changing on Sunday, it felt weird closing shop with some daylight still visible.
Oh, and Sally had been feeling a bit rough the last few weeks.
She tested positive for Covid.
Perfect.
Old 03-28-2022, 02:45 AM   #1658
Grizz1963
Grizz1963's Avatar
I guess the question does come up: “So what has Grizz been up to while Nick is seen working?”
Yesterday I carried on with those jobs that progress the build invisible, not just coffee and biccies, but fitting, unfitting, measuring and cutting, filing, screwing, unscrewing etc.
Have raised the bottom of the instrument cluster to allow a full, clear view of them all.
Then destroyed the binacle.
Too late for tears.
Ultimately, it was a failure.
Number two for the day, after the side light mounting failed to deliver fully and securely for Nick.
Sandwiches for lunch, coffee, biccies etc…..
More planning, cutting, fitting, hoping.
Happy with the positions of dash switches.
Yes, that’s the lot.
I hope.
More cardboard and masking tape work to create the templates for the kick panels and tunnel panels.
Odd shapes and non symmetricalfit means it all takes time.
And more time.
Then transferred to the hardboard and a load of filing, cutting, shaping.
In and out.
Resulting in this.
At which point I pulled the plug on the day and came in.
My back was saying it was enough, and to be honest, no jobs needed doing.
A good weekend again.
No massive big bang progress shots, but many hours filled with small jobs.
Progressing.
PS. I need an MX5 Fog light switch, seems the one from the car is broken somewhat.
Have a good week all.
Old 03-28-2022, 05:06 AM   #1659
Grizz1963
Grizz1963's Avatar
Having tried to make the cluster work as it is…….
A nights sleep, relook at 06.30 this morning, had me dismantle the dash again and bring the cluster indoors.
A couple of people including @kevins and @redratbike made suggestions along the same line.
I decided to dismantle it.
Will need to get some clear polycarbonate and frame it.
And thickness
I think there is a load of mileage in redesign here.
Will look again tonight after work if I get time.
Later gang.
Old 03-28-2022, 05:07 PM   #1660
Grizz1963
Grizz1963's Avatar
Sally is a donkey, not much stops her. Certainly not Covid.
Thanks for the care messages for Sally, the dog and George the cat and of course compliments aimed at @nickwheeler and me.
In the mean time I have released an album to help generate funds for the body and wheels that need painting.
Hope it sells well and generates sufficient funds.
Old 03-29-2022, 03:32 AM   #1661
Grizz1963
Grizz1963's Avatar
Ordered a couple of new switches yesterday.
Rear fog lamp switch (need to still find a slimline one to fit)
An one of these to replace the cigarette lighter plug with.
Thanks to Nick for the suggestion.
Better than plugging a USB extension into the cigarette lighter to get the same result.
On the way home last night the traffic was light so I took a chance to go past my turning to the industrial estate to see if they had some 75mm M6 countersunk Phillips head screws or are they bolts?
To mount the bonnet/hood hinges and allow enough length to hang some supports from under the scuttle into which the wiring loom can rest.
Time consuming jobs, detours etc.
Makes for an interesting build.
Old 03-29-2022, 08:16 AM   #1662
Grizz1963
Grizz1963's Avatar
Bought from my favourite scrapyard.
Cheap.
Record no 111 vice.
24kg weight.
£10.00 or $13.00
Old 03-29-2022, 06:40 PM   #1663
LT7A
You guys are getting into the details now, that is cool to see! I'm sorry to hear that Sally's picked up the covid. I hope that she can get the rest she needs and that it is not severe and that she gets better quickly.
I like your country album. Maybe the next one can pick up on geographical themes. I have a couple ideas: "It's All The Thames To Me" (BTW, I know it's pronounced tams). And "Hoo Is Saint Mary To Yoo?".
Nice grab on the vice. At this point in life, I am striving not to gain any new vices, haha. But that is one that I would happily add to my repertoire. Here, we spell it vise so, fortunately I am able to distinguish between the two. Mostly.
Old 03-30-2022, 03:39 AM   #1664
Grizz1963
Grizz1963's Avatar
Sally is not stopped by much.
Having had to take a week off work (paid vacation) but lost overtime she has not stopped.
The $3300.00 dent the dog put in her emergency savings fund is a huge hole, and at the near minimum wage she earns, it will take her 2 years to regain that from saving and overtime.
Always space for another album
I am a fan of free cash, so my eyes are always open.
The vise was a stroke of luck, there is so much good stuff people throw out, it hurts my head.
Popped out to the metal recyclers yesterday to see if I could find something that is already bent in the shape of the instrument cluster to cut down as a small peak.
No luck, but a beer keg rim would work.
Except it is just too ugly and heavy.
But while rummaging I found a complete, hardly used Record No 111 vise/vice (never sure what spelling is correct.
Asked about it.
“Gotta weigh it mate, then ask the Guv” came the reply.
5 minutes later I had it for £10.00
Now I need a bigger welding table.
I also picked up a few loose bits, declared them and got them for free.
On the way home I made two stops, first to pick up so e brake fittings with no nuts, and then at the local motor spares shop the nuts at 40p each.
@nickwheeler was helpful in sharing a pic for the new guy at Aghabridge of exactly what was needed as he could not locate them, based on my description.
So brake lines can be added now.
And following a 3 hour online training session, Sally and Bonnie popped in so the dog that still is in isolation, as is Sally, could run around in my back yard.
Amazing that 10 days ago this was a very ill dog with Parvovirus.
Now she is nonstop.
Day job is a bit hectic at the moment, and working face to face most days means no chance for quick win jobs.
The weather this week is also less than ideal with cold and rain forecaat.
Have a good day.
Old 03-31-2022, 02:30 AM   #1665
Grizz1963
Grizz1963's Avatar
I wanted to go play a bit last night after I got home and did for 20 minutes, then the chill, and wet decided it was less than pleasant out there and I came inside.
I was going to make some under dash hook brackets to hold the wiring loom up and out the way, but I got very wet out back digging through my scrap pile in the hope to find some ready made bits to adapt.
While I stood deciding what to do next, I made a short clip of the rain falling on the tin roof of the carport and driveway, enjoying the fact I had a dry space, despite now being soaked myself.
Sent it to my brother “Dozer” in South Arica and a minute later he replied with……. “Hey, why not mount that 7.5 ton truck valence as a bikini roof on,the Rezin Rockit?”
What a great idea to at least investigate.
So with so e trimming, figuring a secure method of fixing, it could be a starter.
So, this…….
Goes there:
Masking tape, sharpie, jigsaw, powerfile, fixings……..
Hey, a job for another day.
Maybe.
Old 04-01-2022, 03:02 PM   #1666
Grizz1963
Grizz1963's Avatar
Got a call from Darren today.
Followed by some photos……
Headed in the right direction.
And sparkly.
Can you tell what it wants to be yet?
More work to be done tomorrow.
I do Need this.
Old 04-01-2022, 03:17 PM   #1667
Grizz1963
Grizz1963's Avatar
PS: Also made these…….
Bolted in under the hood/bonnet hinges against the firewall, under the scuttle with inverted T’s welded in place, they will be mounting points for the wiring looms.
Small jobs ehhhh??
Weekend ahead.
Old 04-02-2022, 02:51 AM   #1668
Grizz1963
Grizz1963's Avatar
25 days without a phone or internet, wifi etc when you run a home based office…..
And mobile reception that does not receive any signal.
So yesterday, I actually walked out of my Friday meeting and killed some time.
Weirdly, at 4.00pm a BT Openreach telephone technician arrived, two hours later magically…….. Phone and services restored.
So what else did I get done.
I bit the bullet and cut back the instrument cluster face and peak.
Hacksaw job.
Then took a long tome to shape and file and grind it to a point where the next phase could be started.
This was a very high risk manoeuvre as it was snowing intermittently outside the garage which makes plastics extremely fragile.
I knew I had this piece of plastic for the last 10 or more years, found it, marked out, Stanley knife, prayed and snappe…….d.
More cutting, grinding on the bench grinder……
Loads of scratches……..
Then some towels, cloths and G3 rubbing compound, an hour later I was halfway there, drilled a hole for the speedo reset button.
Followed by more finger polishing, grinding, filing, you get the picture.
I am happy to say, it is far from perfect.
But good enough.
Don’t like it?
Come over, make a new one, fit it.
Next up.
Inbetween helping the telephone company guy sort out my phone and internet, including removing some plugs to speed up my internet microscopically the next job surfaced.
Making a template for that little peak to finish off the cluster once fitted to the dash, after the vinyl is ordered to cover it all.
CAD Rules as @nickwheeler says.
While working on this, I also decided to try fit the cluster from behind, and not out front as planned.
This reduces it by 12mm
And still fits and allows the three loom plugs to be connected (I hope)
After some fine tuning, grinding and a load of bending I think we have a workable solution.
It will get bonded around the trim, and the vinyl will get tucked in behind the clocks etc.
Work in progress yes.
I also sanded and painted the piece and then closed shop at 7.00pm as my bones were chilled working out there with snow still swirling about.
This morning I noticed the outside temperature is at -2’C
Where is summer now?
Old 04-02-2022, 05:19 PM   #1669
Grizz1963
Grizz1963's Avatar
Today was a great day.
Loads of progress, but apparently none visible.
As mentioned by @nickwheeler that’s where we are at this point.
So what did we get done?
Nick made some brackets, welded some on, drilled holes and generally got a load of invisoble jobs done.
Oh, and he smashed some rear lightbulbs on the driveway.
I did some woodwork, metal work, grinded and grinded some more on the dash and cluster.
I also dug out the Rocketpigs that @peteh1969 had 3D printed for me.
They need painting and detailing.
Still trying to figure what to do with the paint.
Old 04-03-2022, 03:18 AM   #1670
Grizz1963
Grizz1963's Avatar
So back to what took 6 hours yesterday.
@Nickwheeler was on electrical and bracket duties.
Making, shaping, welding earths, fuse box brackets etc.
Time flies when you make stuff to last.,
At 5.30pm the wiring loom was removed AGAIN AND HOPEFULLY for the last time for some repairs by Nick.
Leaving the under dash support looking a bit lonely.
More fun later today.
Old 04-03-2022, 03:32 AM   #1671
LT7A
Those are great little T standoffs for the wiring. And it looks like your gauge pod is working out well.
Old 04-03-2022, 03:53 AM   #1672
Grizz1963
Grizz1963's Avatar
Morning,
You still up?
Yes, they are nice, specifically bent to not damage the wires once finally assembled.
So while Nick was making sparks, I carried on making dust and some occasional sparks.
I knew I had to head toward this adhesive and getting the cluster sorted.
But it’s another slow job, to get the right finish.
Cardboard template followed by Dexian shelving donor still giving.
Cut out and rough shaped.
Followed by adding some studs to have hidden fasteners.
Test fit, again.
Followed by my favourite part of the job. Paint
Mainly for preventing rust once closed up in padding and vinyl.
Once the paint dried, I messed it up again by gluing and clamping it all together overnight.
One more job before closing up the shop was to carefully line the edge of the cluster trim with black adhesive and then clamp the screen once carefully laid down, AFTER ENSURING NO FINGERPRINTS ON THE INSIDE OF THE SCREEN.
Typically, Nick and I stood talking for some time, then I dragged out the grinder and powerfile again and trimmed back the ECU bracket, that looks lovely now.
Funny how we decide to stop work and then start again, just doing that one more little job.
I fetched the dash and cluster in earlier this morning to warm up indoors, trimming the excess glue on the dash and masking the cluster for fixing the small cowl next, and leaving it alone.
Chilly outside this morning.
Onwards
Old 04-04-2022, 03:32 AM   #1673
Grizz1963
Grizz1963's Avatar
@pauly will attest to us all being young and happy once.
Or more than once.
6 plus years ago, Facebook reminded me over the weekend, the Chevy C10 was having its V8 and Transmission rebuilt and serviced.
Can it be so long already?
Of course if you,look at the “Not a Project” Prozac etc, it is easy to see.
So,Sunday morning I popped down to the garage early to unclamp fetch the dash and cluster for the next part of their marrying up.
It all takes time.
Masking up the cluster to fix the peak in position.
Once glued up, I wanted to mount my new large vice/vise on the welding table, which became a suddenly distracted clearing operation.
Including cutting up the proposed sunny day roof and trying it out on the car.
I think it is a clear NO.
After that, I got refocussed and started to measure, cut, glue the support strips for the side panels under the dash, over the tunnel.
I also created and prepped, then welded 11 studs to wide plates, to be used to pull the dash into the original fiberglass dash (what is left of it) once the vinyl and scrimmfoam,are applied, as well as switches etc.
Everything does take time
And the result.
I did other odd jobs like removing and etch priming the Land Rover door hinges, they will be black.
When @Nickwheeler came, it was coffee, chat and straight into electricals.
His mission and ambition was to connect the battery and see and hear some sort of life.
After some time he called me over…….
We could see that the ECU was alive, and how many miles the engi e had covered.
Time for coffee and sausage rolls then.
Next up, testing the front circuits.
Lights.
Then after testing he started to resplice the first LED headlight, removing the original plug, as we needed an extra 400mm length to make it all work.
On finishing soldering in new plugs etc, time for a test.
Ooooopppsss….. FAIL !!!
Perplexed we both stood retracing steps, testing plugs etc.
I had had a long day, and was stressing about Mondays two meetings, one may well affect me in a way that I do not care to be affected in.
So I actually insisted in us closing shop by 18.30 and go inside, have a couple of cheese and ham rolls and a well deserved alcoholic beverage.
Nick insisted on taking one more look though…….
But we found nothing at that point, packed away, closed shop and walked away, having hit a small wall.
Next weekend both of us have stuff on, so progress may be slower than we would like.
Hey Ho !!
For those that have managed to stay awake to this point, a quick rubbish 1 minute Video.
CLICK LINK
https://youtu.be/S6Wcetfch1I
VIDEO DOES SHOW IT ALL WAS WORKING.
SO WHAT COULD IT BE WITH REWIRING THE LED LIGHTS ?
Have a good week.
Old 04-05-2022, 03:33 AM   #1674
Grizz1963
Grizz1963's Avatar
Popped in at Aghabridge on the way home to get some fuel hose and proper clamps.
Also grabbed three cans of satin black for any small jobs that need a few squirts of black.
Will be useful to get the fuel lines, tank and engine sides all connected safe;y.
After dinner I was bored, so went down to get the hinges coated in black, they have always bothered me since day one.
Back side.
Front side, multiple coats and heat gun used to warm it all up.
Another 30 minute job out the way.
Time thieves.
On the way home I also popped into the scrap yard to see if they would sell an even larger vice/vise I had seen the other day.
No luck, they use it.
But I did see this little aluminium boat……
Sooooo wanted it, and yes it would be for sale.
Sense prevailed.
Later gang.
Old 04-05-2022, 01:41 PM   #1675
LT7A
I was up late but was gone by the time you replied to my post a few nights ago. The way that you guys are chipping away at things, if you're not careful, that neat little ride is going to be done pretty soon. I live near a river that nobody goes out on. It's a stream compared to your River, but is plenty big to take a boat up and nobody does. Not in the area I live in anyway, further downstream it's run by larger boats. I really want to get one about that size, maybe a little bigger, that one is 8 ft? I want to be able to row it and putt it around a little with an outboard on it.
