Old 03-26-2022, 03:28 PM   #1
Peanut74
MC and Proportioning valve advise
Ok, now that the windshield is installed I working on the brakes. I am at the point to where I need to order a power master cylinder and an adjustable proportioning valve. I have read all the threads that I found on the site but they did not match my setup.
What I have:
-'67 cab/ pedals
-'71 frame/ All brake lines (3/16"OD front line, 1/4"OD rear line)
-'71 front disc brakes
-'71 power brake pedal rod
-Rear disc brakes (Single piston calipers)
What power master cylinder and adjustable proportioning would you recommend? Would like to stay with a OEM MC if possible.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 03-27-2022, 11:44 PM   #2
Peanut74
Re: MC and Proportioning valve advise
Finally found a thread that had some useful information:
http://67-72chevytrucks.com/vboard/s...aster+cylinder
Looks like I should get a 77-82 Corvette MC or early GM, Autozone P/N NM1521. I will research them tomorrow and see how the fit up. As for the proportioning valve I think I will look at the adjustable Willwood valves. Will probably call them to help me sort out the one I need.
Old 03-28-2022, 07:59 AM   #3
Alex69c10
Also in the same boat! It’s a bit of a nightmare to find. I just want something I can bolt to my booster with proportioning valve and will mate to my inline tube kit!
Surprising there’s few definitive threads on it.
Alex69c10 is offline   Reply With Quote
Old 03-28-2022, 08:50 AM   #4
Grumpy old man
Grumpy old man's Avatar
The disc drum CPP master , mates up to the stainless inline tube brake line kit .
https://67-72chevytrucks.com/vboard/...d.php?t=711288
https://www.inlinetube.com/products/sctb67d4
https://www.classicperform.com/Store...ck/6772BBD.htm
Double check part #'s before ordering .
