Old 04-01-2022, 03:30 PM   #1
Tug87
Wiring Help Please - ID Wires?
Hi All,
First let me say I'm not be best at wiring but would love to learn more.
I'm having some trouble with my Suburban. My right turn signal turns on when I apply brakes as well as the gauge lights.
I recently replaced the rear brake light and sign marker light wiring harness as it was very brittle and I'm thinking these extra wires may be the cause of some of it.
Would you please help me identify the following wires (pictures attached)?
On the drivers side I have a second connector after the tail light connector with two wires entering and exiting the connector.
- One of the wires is in the body harness and runs through the headliner down the D post into this extra connector. Seen in picture 1
- The other enters the back of the body harness which connects to the tail light connector. Seen in picture 2
On the passenger side I have an extra brown wire coming out of the body hardness which runs though the headliner and down the d post.
Lastly does anyone make trailer wiring for the 71 suburbans? Thank you!
Tug87 is offline   Reply With Quote
Old 04-01-2022, 06:06 PM   #2
MikeB
MikeB's Avatar
Re: Wiring Help Please - ID Wires?
What year is the vehicle? I ask because of the "87" in your member name.
Does the rear have a single 1157 bulb per side? How do the sockets look?
Also, you said the right turn signal and the instrument panel lights turn on when you apply the brakes. How about if you engage the right turn signal? Does that cause any other lamps to come on?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-03-2022, 03:04 PM   #3
HO455
HO455's Avatar
Usually when you have problems like yours it comes from poor grounds. Electricity takes the path of least resistance and that path can at times be though other lights.
Your Suburban taillight housings need to have good electrical connection to the body.
To troubleshoot this I find it easiest to use a 20 foot long test lead. Hook one end to the negative post in the battery and use the other one to ground the light housing when the turn signal is operating. If the housings ground is poor it should start operating correctly when you touch the test lead.
You may find that you have to touch the metal part of the bulb socket to get the light to work correctly. If so there is corrosion under the crimped area of the socket where it attaches to the housing.
Once you determine the ground is bad you need to remove the housing and clean the mounting bolts and the area around the holes they go through there needs to be shiny metal to metal contact between the body and the housings. I use copper anti-sieze to coat the shiny unpainted areas, it allows good electrical grounding and keeps those areas from rusting.
GM used star washers to cut into the paint and get the housings to ground. However GM used no compound to prevent rust so eventually the housings loose there electrical connection. It was fine for the assembly line and getting through the warranty period.
On your connections the second connector on the drivers side should be te fuel tank sender wire. And if memory serves me correctly the back up lights..
On a Suburban the rear harness runs up the driver's side A pillar and back above the windows to the driver's side rear corner where there is the passenger side wires split off and cross over the rear doors/hatch. Both sides drop down to the areas in your pictures.
The wiring colors will match the pickup colors in the harness schematics post here on the forum.
There is a connector under the dash in the area of the headlight switch where the rear harness connector plugs into the Suburban ONLY under dash harness. I say Suburban only but I don't know for sure if Panels use the same set up. I do know that a pickup harness won't work without a bunch of work.
I don't know of a Suburban specific trailer harness but a call to M&H or AAW would confirm that. A low volume harness like that isn't likely to be listed on their websites.
Good luck and keep us posted on your results,.
RIP Bob Parks.
Old 04-03-2022, 09:38 PM   #4
BigBird05
Try a new front turn signal bulb.
BigBird05 is offline   Reply With Quote
