Old 04-02-2022, 06:11 PM   #11
IBFester
IBFester's Avatar
Re: another H pipe exhaust question
Originally Posted by LS short box View Post
In regards to the choke if your intake is original sometimes the heat cross over gets plugged with carbon so the exhaust can't flow thru and warm up the choke coil.
if I remove the heat riser will I be able to clear it if it's clogged?
IBFester is offline   Reply With Quote
