02-08-2016, 05:04 PM | #26 | ||
Re: Cab/Roof/Clearance Lights- Who Has Added Them?
11-06-2018, 09:23 AM | #27 |
I have the Yankee aftermarket lights similar to Canuckvetter's truck on my 69 C10. Evenly spaced out, but mine are all lined up with the truck and the outside lights are not angled like they are in his pic.
I'm the third owner of the truck and the second owner thought they were factory, however I'm thinking dealer installed. The original owner was a farmer that bought the truck for his retirement. My truck came from Legal Ab so it might have been a look the Northern AB farmers liked at the time. I think they didn't look right on the truck when I got it, I changed out the smoothies for some rallies and added a rack on the back and looks better now. Would improve the looks with West Coast Jnr's, rather than the peeps currently on the truck, but this truck needs the clean uncluttered look and I'll move the clearance lights to my K20 when i'm reads to paint the cab. Chris
1969 Chev C/10 1972 GMC K2500 Custom Last edited by CRMW; 11-06-2018 at 09:30 AM. |
11-06-2018, 10:19 AM | #28 |
I got mine from LMC a few years back. At first I liked them even though I kept leaving them on, but after a while I didn't bother to turn them on. After a short while during the first winter the salt from the roads just killed them. The chrome pitted up real bad even with the wax and other products on them. I took them off when I redid the truck and haven't missed them or the look. Every one is different so do what makes you happy eh. After the first drill hole the rest are easier!!! Have a good one.
11-06-2018, 10:44 AM | #29 |
I was born and raised in one little 900sqft house, and my Dad ran the local hardware store. It was often -30F to -40F and we'd watch for the cab lights on Dad's truck coming back through the winter storms. Sounds like something Cormac MacCarthy would write about, but watching for those lights is really seared into the old brain! They served a purpose too!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-06-2018, 05:50 PM | #30 |
How did I get this OLD!
All 3 of my 67's have maker lights. All Oshawa trucks. Only one has factory markers. The bottom pictured truck. The others were aftermarket installs due to the placement. Good thing I like marker lights. All 3 have side mount spare tires too. Must have been an Alberta thing back in the day.
http://67-72chevytrucks.com/vboard/a...1&d=1541540366
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
03-29-2022, 05:10 PM | #31 |
Love all the comments- drill! Don’t drill! Resurrecting an old thread, I plan to add Yankee 77 cab clearance lights to my 63 C50. I just really like the look on a big truck. The roof already has rust coming through so I think there may be a mouse nest in the pillar, plan to replace the roof section “some day”. I found a set of decent shape on EPay with white lenses, but the fat rubber, for reasonable price, and another seller has amber lenses for $10 each that’s my plan anyway. I will enjoy how it looks for decades and the future owner can worry about the cab rust!
I also found this installation diagram I plan to use, maybe it will help someone else. It was in the 1965 Chevy Truck Vehicle Info Kit (GMC Heritage site), but should be good for measurements on most cab roofs.
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
03-29-2022, 10:55 PM | #32 |
The Older Generation
I just installed the Yankee 77's on my '71 Dually build. http://67-72chevytrucks.com/vboard/s...d.php?t=829820 Starts at post #119 on page 5. I have two different original instruction sheets for the Yankee 77's. One instruction sheet just lists the '66 truck locations, and one sheet shows the '66 and '67 cabs. The sheet that shows the '67 cabs has the lights straight in the corners instead of angled. That is the way I installed mine. I also have an original Yankee 77 wire loom that I can get you the measurements and pictures off of if you need them. I like the old school look of them.... LockDoc
03-29-2022, 11:13 PM | #33 | |
03-30-2022, 11:06 AM | #34 | |
I drilled the holes. This is not a perfect cab so I had no qualms about doing it. I just had to measure 3 or 4 times so I only had to drill once.... .. It's usually measure twice, drill once, but that doesn't work for me any more. LockDoc
03-30-2022, 06:35 PM | #35 |
LockDoc,
Are you using the screws on your lights as the grounds by grounding each light to the roof, or did you run a separate ground for each light and link them together then ground them?
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
03-31-2022, 09:26 AM | #36 | |
Screws ground them. You just have to make sure you have a good ground from the battery to the engine and from the back of the engine block to the cab. LockDoc
03-31-2022, 12:19 PM | #37 |
Here is a 70 pickup I used to have. I have put cab lights on several trucks I have had. I really like them. You can also see the side turn lights on the front fenders. I won't put them on the 72 I have now as I want to keep it all original.
I wired them into the tail light circuit but put a low amp fuse in line in case there is a short it won't put out the tail lights. George |
04-02-2022, 10:06 AM | #38 |
If a person wanted to install a set of these how much of a job to run the wires? I take it they are run up the windshield post, correct?
04-02-2022, 03:04 PM | #39 |
I just did this. It isn't really easy but it is doable. Here is a video posted by one of our members, "Tx Firefighter" on YouTube. https://www.youtube.com/watch?v=-53fdPXgVLA I tried this but didn't get it to work for me. I had an old speedometer cable so I used the center cable out of it to snake down the "A" pillar and pull a string back up with it. That worked pretty good. You can also run the wire to the back of the cab and then back up front with the fuel and dome light wires but I don't think that would be much easier over all. I looked up a thread on someone replacing a roof skin to get an idea where the hole was that the wire needs to go down through. that helped too. LockDoc
04-03-2022, 11:49 AM | #40 | |
04-03-2022, 01:25 PM | #41 | |
That is correct. LockDoc
