#126 |
Re: Slammed 1966 GMCummins 12v
Well it’s all done…. This picture in the snow was a few months ago. I have since taken it for its first drive and everything seemed to work as it should. I’m in the middle of fixing a small trans leak but other than that everything is how it should be. The AC will be getting charged soon. I’m still messing with the waste gate to juggle when it should open. I’ve see a max boost number at 60psi so far. It hauls ass for a c10, I’m aware I have way to much turbo on this VE pump but it doesn’t blow black smoke everywhere you drive the compounds clean that up good.
#127 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice work! 60psi is pretty good for a VE. Just drive it and enjoy it now!!!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#128 |
Still one of my favorite builds man, well done.
Please come one out to Alberta some time to show it off. Ron. |
#129 |
Forgot to mention, I’m using a 47rh tranny (4 speed with lock up converter) because I couldn’t get the TV cable to function properly I bought a full manual valve body from Muldoons Diesel. It works absolutely amazing, the manual VB with my pro ratchet shifter is an amazing combo. They have some sort of tranny dyno they run the VB on before it’s shipped. My 4th (OD) and lock up are run off 2 toggle switches on the shifter itself. And if your having a problem with the trans leaking at the dip stick tube, buy a Lokar anchor tight locking dip stick. Expensive but real nice piece. You have to drop the pan in order to get a backing nut on but it’s worth a clean floor.
#130 |
Cool build & liking the updates.
#131 | |
#132 |
These are manual switches, i have the expensive electric system in my Lincoln and its given me a few problems, enough that i didn't feel the price was worth the pissing around again. i got 2 of these switches from airlift, and the other two from a Flying J truck stop. a good friend of mine who is a trucker said they are just air seat switches from the big rigs. there was a $20 per switch price difference. $30 from the truck stop and $50 from Summit.
i don't have much time on the manual air system so only time will tell, i will post updates all summer. |
#133 | |
#134 | |
yea he claims the lines, push lock fittings, bags and switches can all be purchased through the trucking industry. if i ever do another budget bag build i will look into it further. it would be nice knowing you can source replacement parts everywhere in north America if you ever ran into a problem on the road.
#135 |
I have a little larry touche on my orange truck and I doubt I'd buy another. I could have done the same thing with semi seat switches just like you said. Your friend is correct. Any big truck shop will have a wide assortment of DOT fittings and a lot of them are plastic body with brass threads and are push connect. They usually always stock line and misc bags too.
On your constant pressure valve body, does it shift hard all the time? On my Corvette I have a constant pressure valve body as well with the TV wide open all the time. It's a pretty harsh shift at part throttle. ![]()
#136 | ||
I had a barbed style paddle valve in my possession & tried removing the barb fittings hoping that a PTC fitting could simply replace it. It was a no-go on the one I tried as it basically destroyed the switch trying to remove the barb fittings. I have just been on the hunt for some to help a guy out where I work that wants to put some air-ride on his truck but he has a super low budget. It seems the PTC style are only available @ the name-brand sources when I've searched. Knowing how other things are 'slightly' marked-up, I was trying to find them from different sources w/o the 'brand' tax. I like the DOT rated PTC as they make service work easy & I just don't feel the barb style fittings are as strong when it comes to holding on to the airline.
#137 | |
no the valve body shifts good, its harsher than a stock shift obviously but its not crazy. I've been in some gas stuff that just hammers gears and it gets fairly annoying just cruising around town. with that being said if i shift with the converter locked up it will snap your head back lol, I've only done it a couple time by mistake but its a different feeling for sure. I'm really happy with the build so far, it cruises down the road so nice and the suspension seems to be able to handle the heavy ass cummins over top of it. you were right tho the back of my truck is covered in soot already, im already looking into putting a taller stack on.
#138 | |
i hear yea man, the 2 i was given from the flying J were PTC style. ill do some digging to see who's name is attached to them. if i remember correctly there was 3 different styles to choose from. all used the plastic line with either a barb, PTC or a compression ferrule type with drive up nut.
#139 | |
Thanks for your efforts though.
