Old 06-11-2002, 10:22 PM   #1
Ironhorse
Ironhorse's Avatar
Question Rubber Floor Mat and what else?
I'm sure this has been covered before but need to ask. My '71 4x4 is getting closer to coming out of the paint & body shop. Have no idea what is original floor covering other than the black rubber floormat. When I bought the truck there was't much of that left either. I have a repop floor mat for 4x4 with tails but what do I need to go under it as far as sound deadening, insulation, moisture barrier? Any suggestions ? Thanks in advance to all replies.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is online now   Reply With Quote
Old 06-11-2002, 10:33 PM   #2
Benrs86
Benrs86's Avatar
there is molded carpet you can buy, or just the white 3/16 inch foam, then the mat, if your goin original. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 06-11-2002, 10:40 PM   #3
Low69CST
The factory had some kind of cheap insulation, I think I threw all of my old stuff away. You can buy replacement original stuff like mentioned above, you can also get some insulation from summit that is much better, or you can take the "got money to burn, overkill" method like me and dynamat it.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-11-2002, 10:45 PM   #4
Low69CST
Oops, forgot the picture
Old 06-11-2002, 10:46 PM   #5
Low69CST
Another one
