Old 04-10-2022, 11:57 AM   #1
bigmoe
bigmoe's Avatar
Any suggestions to fix this horn cap?
I've got a 65 Belair steering wheel I'd like to clean up. The horn cap is held on by two spring clips. One clip has come off. The rivet edges have come off. Before I look for another cap I'm wondering if anyone has any suggestion to repair this one. The rivets are actually part of the casting. See pics.
bigmoe is offline   Reply With Quote
Old 04-10-2022, 12:02 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Any suggestions to fix this horn cap?
I hate to say JB Weld but...
Old 04-10-2022, 12:15 PM   #3
bigmoe
bigmoe's Avatar
I'll have to check if there's enough depth but maybe I could drill it out and use some of these knurled rivets if I could find a small enough one.
Old 04-10-2022, 01:13 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
allen cap screw?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-10-2022, 01:59 PM   #5
jayoldschool
Moderator
JB Weld the clips on the posts. I did exactly this on a couple wire wheel Cadillac center caps and it worked perfectly.
jayoldschool is offline   Reply With Quote
Old 04-10-2022, 03:50 PM   #6
bigmoe
bigmoe's Avatar
Got JB Weld on one side and when it sets up I'll move the clamp and do the other side. I drilled down in the center of the hole a bit to giv it something to bite into. If this doesn't work Ive got some tiny knurled rivets coming from Ebay. I could probably only drill down 3/16" without going through though.
Old 04-11-2022, 09:58 AM   #7
bigmoe
bigmoe's Avatar
Well the JB weld is holding it pretty good.
Old 04-11-2022, 11:20 AM   #8
cwcarpenter98
cwcarpenter98's Avatar
Nice! Since it's a part that won't be frequently removed, it'll probably stay together for a long while
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
