#37 |
Re: Valve seals
For measuring quench I would use a straight edge across the cylinder, then a feeler gauge. Measure where the corresponding flat area of the head would be. This is your quench area.
I would also use this time to find true TDC and mark your balancer accordingly with one of those aftermarket timing tape strips.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
