Old 04-13-2022, 09:32 PM   #1
scott123
Paint question/door panels
Is there a code for the black on the metal door panels? I am debating on going back black or color matching to the door.....yet to decide.
Scott
scott123 is offline   Reply With Quote
Old 04-14-2022, 02:23 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Paint question/door panels
The code for 1970 can be found HERE and I suspect it's the same for other years.
Old 04-14-2022, 02:42 PM   #3
hemi43
hemi43's Avatar
Scott
Back then black was black. When I used to paint black repairs, I always used a pre-packaged black which needed no custom tinting.
For interior colors, the sheen is the most important. If you paint those door panels with a high gloss black it won't look right and you will scuff it anytime you get into the truck. You want a satin or semi-gloss (not flat)
This is the best product I've found for satin a black finish. Been using it over 30 years and always had excellent results. You can buy it in quart cans as well as spray cans, but for a large piece like a door panel I wouldn't use the spray cans. It's also excellent for engine components because it gives the parts a factory looking finish.
https://www.3m.com/3M/en_US/p/d/b40072367/
hemi43 is offline   Reply With Quote
