Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-15-2022, 09:31 PM   #1
Troy Sr
Troy Sr's Avatar
Blast Cabinets
Hello All,
While going through 7dee2 (Brett)'s 67 Camaro Build I was looking at his blast cabinet build, I thought I'd like to get some input from those that have one and have maybe modified them. I have the same unit from Harbor Freight and have added some updates. I added the bottom abrasive pickup kit, the foot pedal kit, a new/better nozzle, and a shop vac.
My compressor is a Craftsman 6 1/2 Hp 60 Gal vertical tank, its 240 V, max pressure 125 psi, 15 scfm @ 40 psi and 11 1/2 scfm @ 90 psi.
It does do "ok" blasting sometimes but not always. I have glass beads in it now and I had some black aluminum oxide in it before I updated it. I really want it to remove rust better and faster than it does now. One of the problems i have with it is the glass beads do not settle very well back in to bottom, they stay on the upper edges and stay on the sides of the "funnel" so I have to shake it or beat on it to get it to settle a bit. the other day I saw an electric motor that vibrates it to help.
Does anyone have any ideas to help this cabinet to work better? Also what's the best blast media you use? Thanks for your help!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 04-15-2022, 10:39 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Blast Cabinets
The glass beads are a very fine abrasive... if you want to remove rust better, then get sand..obviously the coarser grit the better..I run 80 and 120 in mine
At work, we use glass beads, we cut some teflon sheets to fit the sides to help it slide down better..moisture also creates problems..so we hang decadent bags under the screen
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-16-2022, 10:55 AM   #3
Getter-Done
Getter-Done's Avatar
Re: Blast Cabinets
For rust removal, I use Aluminum Oxide.
It's the Longest-lasting media for fast, effective rust removal.
Here is a list of other abrasives and their application.
Glass Bead/Works best on softer metals like aluminum, brass and die-cast.
Walnut Shells/Remove paint, carbon deposits from ferrous metal, clean internal parts.
Ground Glass Media Free 40/70 Mesh Non-hazardous silica substitute to use for light rust removal.
Silicon Carbide/Sharp edges for heavy rust removal, welding/brazing prep, glass etching.
Rust Remover Bicarb Soda w/ 10% 70 Grit Alum Oxide/Most aggressive soda for rust removal; 90% soda, 10% alum. oxide.
Now for the media issue not sliding back down, I found a kick drum pedal at a scrap yard one time it works great. You can leave you hands in the gloves and you don't have to knee the cabinet
I also have a small vibration motor on there.
84 Chevy K-20
Old 04-16-2022, 01:05 PM   #4
mongocanfly
Re: Blast Cabinets
Love the kick pedal idea..!!..
Where'd you get the vibrator motor...that looks nice..I found a few, but they were on the big size,,,,or 12v
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-16-2022, 01:12 PM   #5
Getter-Done
Re: Blast Cabinets
Mine is a little different.
This is a link for example.
Link: https://www.ebay.com/itm/16431955818...2Cchnl%3Dmkcid
84 Chevy K-20
Old 04-16-2022, 02:17 PM   #6
mongocanfly
Re: Blast Cabinets
Thanks..!
I found the one in your pic above..looks like under $45 ..not bad
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-17-2022, 01:51 PM   #7
Troy Sr
Troy Sr's Avatar
Re: Blast Cabinets
Hello again All, I changed out the glass beads with some black iron oxide and man what a difference!!!! I was able to blast my control arms much faster!!! I think the only problem I have now it the piece of crap compressor! Thanks for your help!!!!
Take Care
Troy
Old 04-17-2022, 10:43 PM   #8
Getter-Done
Re: Blast Cabinets
Here is another upgrade I have.
This is a simple short U tube video below.
There are tons of videos on this same upgrade.
It can also be done with Pipe & ball valve from the Box stores.
84 Chevy K-20
Old 04-29-2022, 10:45 PM   #9
Troy Sr
Troy Sr's Avatar
Re: Blast Cabinets
Well today I tore down my Air Compressor and rebuilt it. The cylinders and the seal rings were SHOT!!! I just started it up and it went from 0 psi to 125 psi in less than 5 mins!!! Now I think my blasters gunna kick butt!!!! Yipee!!!!
Take Care
Troy
Old 04-29-2022, 11:00 PM   #10
Getter-Done
Re: Blast Cabinets
That is great News
84 Chevy K-20
Old 06-24-2022, 12:15 PM   #11
doug_p
Junior Member
doug_p's Avatar
Re: Blast Cabinets
Steel grit also works very well, but if you don't do some "protecting" of the inner cabinet, it will eat through the cabinet also. Rust removal is no issue for steel grit - comes in various grades also, and honestly in my experience lasts far longer than anything else.
doug_p is offline   Reply With Quote
Old 06-24-2022, 10:56 PM   #12
Getter-Done
Re: Blast Cabinets
Yeah
I use a stainless steel Sheild behind what I am blasting.
if I use Steel shot.
With your Idea I may cut some sheets at work to protect my cabinet.
84 Chevy K-20
Old 06-25-2022, 06:25 AM   #13
doug_p
Junior Member
doug_p's Avatar
Re: Blast Cabinets
So there is a difference between grit, and shot - you are probably aware. Shot is like small bb's, grit is just that, sharp and angular. They both leave very differing surface prep's once blasted.
We use thick mud flap style rubber material to line the inside of our cabinet at work, usually 3/8".
Old 06-25-2022, 05:55 PM   #14
Getter-Done
Re: Blast Cabinets
That is a great Idea
Eastwood has some good info on different media.
Link: https://www.eastwood.com/abrasive-blasting.html?cat=104
The old guy I send some of my Bigger stuff to, He has Ground up Light switch covers for media.
I just have the simple stuff.
Walnut shell, Steel shot and alum. ox
84 Chevy K-20
Old 09-14-2022, 09:53 AM   #15
dsraven
Re: Blast Cabinets
when I went to pick up some more silica sand for my cabinet blaster, the yard guy asked me what I was using it for. when I told him he asked if I have a cabinet full of powder. I said, well, yeah it doesn't seem to last long. he recommended garnet for cabinet blasters because it doesn't shatter upon the first impact and make powder. I switched over for a bag to test it out. it works better for sure and partially, i think, because it takes more impacts before powdering up
Old 09-14-2022, 01:56 PM   #16
mr48chev
mr48chev's Avatar
Re: Blast Cabinets
Silica sand isn't good for your lungs either. lot of people use it because it is cheap and easy go get but the dust off it is what causes silicosis.
Media for sand blast cabinets has improved greatly in the past 20 or so years as so many people have blast cabinets at home.
As far as compressors go, it takes a pretty good and big compressor to keep up with any sand blast cabinet with the amount of air they use.
My ongoing truck projects:
Old 02-10-2023, 11:33 PM   #17
sixty2pcup
sixty2pcup's Avatar
Re: Blast Cabinets
Some good information. thanks
sixty2pcup is offline   Reply With Quote
Old 02-21-2023, 08:59 PM   #18
cbeerman
Re: Blast Cabinets
+1 on the Garnet and it doesn't absorb moisture
Just regulate your air pressure so it doesn't hit too hard and shatter the media.
cbeerman is offline   Reply With Quote
Old 02-28-2024, 02:12 PM   #19
HO455
HO455's Avatar
Re: Blast Cabinets
What PSI are you running at to achieve that? I would like a ballpark starting point.
Thanks in advance.
RIP Bob Parks.
HO455 is online now   Reply With Quote
